error code 113
Old 19 Aug 2010, 11:19 pm
Default error code 113
Will error code 113 keep me from starting my engine.05 manual 5 speed non turbo 70k wont start all of a sudden keeps throwing error code cant seem to get it fixed please help. it does turn over but that is it
Life is great when rolling with a beagle dont leave home without one
Old 20 Aug 2010, 12:26 am
Pt_Magnesium's Avatar
Default Re: error code 113
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage You can find the Full Error code list here Error Codes
Pt Cruiser 2006 Limited Edition color:Magnesium Pearl
Old 20 Aug 2010, 06:49 am
Beagledad,
From what I can gather in a search, the IAT sensor could stop your engine from starting. Do you know where the sensor is? It's a very delicate sensor that's pushed into the rubber hose between the air filter and throttle body. It could be unclipped from the electrical wires or somehow not even attached to the hose. The end that measures the actual air temperature is a tiny little thing that can break off very easy and disable the sensor.
Old 20 Aug 2010, 10:56 am
I know where it is, your right about how fragile it is.I checked for continuity ok, check voltage max was 3.99. My wife's jeep compass has the same sensor (considering they put the pt as a truck for some reason) still not working.I looked over all the wiring nothing of concern . I am at a loss
Old 20 Aug 2010, 11:17 am
Dad,
You say it turns over, just doesn't catch to start up? You have a couple things to look for, spark, fuel and sensors that send the signal to the computer (Camshaft/Crankshaft). Most of that would send a signal to throw a code. Take the negative battery cable off again, wit 10 minutes. Try starting again to see if it's the same code.
Old 20 Aug 2010, 11:57 am
Checked what you have noted. Disconected neg several times same thing over and over again. could the timing belt (to tight or loose) cause that error code.In one of my serches it was mentioned breifly but no details.It was recently changed and everything ran good for a week and now this.what to do scrap yard keeps coming to mind but i love my pt i want it back dont have $ for mechanic i realy love my little 5 speed help
Old 20 Aug 2010, 01:20 pm
The timing belt along with the serpentine belt both have a tensioner that's supposed to keep just the right tension on the belt, so it shouldn't be too tight.
I'm sort of out of ideas for your code.
Old 20 Aug 2010, 01:57 pm
You have a five speed, did you try push starting to see if it will start and run?
Let me look through some of the diag procedures for this code. I'll report back shortly with some more ideas.
-Chris
Old 20 Aug 2010, 02:37 pm
Well according to Chrysler, the only possible causes for this code are a short in the wiring, a bad sensor, or a bad PCM.
If you double and triple checked both the hot wiring and the ground wiring and you've swapped the sensor for a known working one, the problem may very well be a bad PCM, which would explain why the enine won't start.
-Chris
Old 20 Aug 2010, 02:41 pm
Thanks Chris. I'm sure Beagledad will thank you but not be happy with your answer.
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
ERROR CODE PLEASE HELP Andrew514 General Turbo Discussions 2 27 Jun 2009 10:52 pm
S1 error code??? mtnbktrek Stage Turbo Kits 2 24 Feb 2009 01:42 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
Error code?? whiteknight Tech & Performance Forum 3 15 Mar 2008 10:29 pm
