Engine fails after Spark Plugs and Wires installation
Old 20 Aug 2010, 12:34 am
Pt_Magnesium's Avatar
Unhappy Engine fails after Spark Plugs and Wires installation
Pt Cruiser 2006 Limited Ed. I replace the old spark plugs by E3 (gap 0.40 fixed)spark plugs, old original wires by a Mopar Performance wires and stock Coil by a Screamin' Demon Coil. But when i start the car a problem came out. The engine began to fail (like one spark plug doesn't work) and the check out engine light up! maybe a bad spark plug from factory? can someone help? i double check the installation.
Pt Cruiser 2006 Limited Edition color:Magnesium Pearl
Old 20 Aug 2010, 12:58 am
Freezinghot's Avatar
Default Re: Engine fails after Spark Plugs and Wires installation
It could honestly be a number of things to do with how you might have installed your add-ons. I would start by seeing if you can get any error codes to know where to start. No need throwing guesses at it if your car will tell you by itself. just me opinion, someone might chime in soon and know exactly what it is
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 20 Aug 2010, 07:04 am
Right, follow the advice above to see if there's any fault codes. Personally, I'd take out the screamin demon coil and put back the original. There good and bad reports about that coil. The original coil, unless your having problems is good enough for PT's running close to 300hp. It supplies enough voltage for any add-on you can think of and it's easy enough to swap to see if that's the problem.
You have the engine light so you will get some sort of code from the computer to help narrow down the problem.
How to retrieve fault codes.
Old 20 Aug 2010, 09:07 am
Dino's Avatar
I agree with Crewzin the easiest thing would be to reinstall the original coil to see if problem goes away. Also make sure wires are pushed down hard they take some force to pop on.
Old 20 Aug 2010, 10:37 am
Agree - takes a determined effort to get the wires on.
Also try resetting the computer by disconnecting the battery.
Old 20 Aug 2010, 07:57 pm
Hi - Well, to tell the history short...
I replace the new coil with original stock coil (problem still the same)
Stock coil replaced with the new one (again)
No error code appear just _ _ _ _ DONE
I have do an extreme research of those E3 Sparks and jumm those sparks have a fixed Gap of 0.66 (measured with a gapping tool)
So i went and bought a new set of sparks, the autoparts sold me (Motorcraft-Ford sparks) i gap those sparks to 0.40 wide but they didn't fit well, too short in diameter compared to the stock (Champion Spark) the wires hardly reach them thoroughly.
Finally went to a local Pep Boys store and find a nice set (same Champion spark long diameter) BOSH Platinum +2 (Gap 0.40 fixed) I will install those Bosh tomorrow but at least the check engine did not appear again and electric intermittence to the engine was reduced when Motorcraft-Ford sparks was intalled.
Old 21 Aug 2010, 04:05 pm
At last everything works perfect! BOSH Sparks fits perfect. Wow !What a difference compared to old stock wires and spark plugs! And the Airraid filter will arrive to my hands soon. Lesson Learned= E3 Spark Plugs do not work on Pt cruiser 2006 and i think i can assemble and dismount all parts again and again with my eyes closed. (i do it 4 times) to resolve the issue.
CHANGING SPARK PLUGS & WIRES?? mjb457 Tech & Performance Forum 10 21 Oct 2009 03:01 pm
Spark Plugs & wires PTPapa Tech & Performance Forum 5 07 Apr 2009 11:56 am
Going for the spark plugs & wires PTC06Peet General PT Cruiser Discussions 1 19 Feb 2009 06:44 pm
Installing spark plugs and wires hangtym3 General Turbo Discussions 11 18 Sep 2005 12:41 am
Should I change my spark plugs/wires? crazie.eddie Tech & Performance Forum 8 18 Sep 2004 09:30 pm
