Transmission 2000 PT
Old 20 Aug 2010, 07:27 am
Default Transmission 2000 PT
New to forum, seems like great site. My problem is with a 2000 PT that will not shift from 1st gear. Car seems to be in "limp home" mode. I have been told there is a sensor or solenoid around the front bumper that may be the culprit. Any help will be appreciated.
Thank You
Dickie Wilson
Old 20 Aug 2010, 08:39 am
Default Re: Transmission 2000 PT
Welcome to the forum.
A sensor or solenoid around the front bumper that won't let your car out of 1st gear? That's a new one. Never heard of that. Do you have a "check engine" light lit on the guages? That will let you know if the computer sees a problem by setting a fault code.
There's a transmission solenoid pack that a lot of owners have had to replace but that usually sets a code (P0700) and lights up the Check engine symbol.
Have you had the PT since new. Has the transaxle ever been flused?
2000 PT won't turn over Confucian General PT Cruiser Discussions 3 12 Jul 2010 07:27 am
Formula 2000 @ TMP TMPracing Canada PT Forum 0 24 Nov 2009 09:08 am
What changes have been made from 2000? oldretiredfred General PT Cruiser Discussions 14 12 Jul 2009 12:48 am
350 + HP for around $2000.00 coopj40 Turbo Performance 7 02 Jul 2006 08:01 pm
