Sensor testing
Old 23 Aug 2010, 04:28 pm
Default Sensor testing
Could someone tell me how to test the camshaft and the crankshaft senor. 1 yr and 2 month ago my 2001 would not start either the camshaft or the crankshaft code came up. I was called away before fixing it. While away my girlfriend didnt keep the battery up so no code now. How do I test them?
Old 23 Aug 2010, 04:51 pm
Default Re: Sensor testing
I would think the only way would be to test them with a scanner. Are you saying that even if you put a new battery in, it won't start and you had a code before that? Maybe the new battery will turn the car over enough for the computer to get a new code when it won't start.
Old 23 Aug 2010, 05:53 pm
now that you mention it i have tried to start it for about 10 mins and no codes. I remember the codes being there when I left. I need to look further into this why codes have not reappeared
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
Testing PtDaddy Testing 0 20 Oct 2004 02:04 am
testing 123 dev Testing 9 23 Jan 2004 12:18 pm
TESTING 1 2 3 blue Testing 2 09 Dec 2003 03:58 am
