I'm not quite sure what you're talking about. All you need to do is hand turn the engine (with the belt still on) until the timing marks line up. If they're off for some reason, line up the crank mark, remove the belt, then line up the cam mark.
-Chris 2010 PT Cruiser Classic, Deep Water Blue ![]() |
On the belt it has the cogs that rides on the splines of the crankshaft
and waterpump and the cams. Those are worn down. (no cogs). They are missing down around the crankshaft, so if i turn the crank it will just spin and the rest of the motor won't spin. So can't line the marks up. I hope everyone can understand what i'm talking about. I'm at work and have to hurry to write this. thx |
Veracruise,
Are you saying there are teeth missing (9 or 10) somewhere on the timing belt? As far as I know, the whole belt should have teeth all around it. None missing. I called up pictures on the net of new timing belt for sale and none of them have any teeth missing. I think the first thing you have to do is replace the belt. |
yeah if you're missing teeth on the belt, you need a new one ASAP! got mine back today along with my PT, and the belt snapped in two approximately 65k after replacement previously. if you're wondering about it, you probably should replace it, and your water pump too since you're already at that point
You guys need to read a little closer
![]() He's in the process of replacing the belt, but because there are teeth missing he can't line up the marks properly. I would release the belt tension and rotate just the belt itself until there are some teeth under the crank, then put tension back on the belt and line up the marks.
there has to be a way to do the timing marks with belt off, because a lot of people wait until the belt breaks before putting in a new belt.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
gotta be careful, otherwise your tbelt will look like this:
Thread Tools | |
Display Modes | |
Timing belt | weighit | General Turbo Discussions | 27 | 26 Dec 2012 06:49 pm |
Belt change help - Not timing belt | skfloyd | Tech & Performance Forum | 2 | 23 Apr 2010 11:23 am |
timing belt | skydj1 | General PT Cruiser Discussions | 5 | 07 Apr 2010 02:40 pm |
what timing belt to use? | 02ptlimited | Tech & Performance Forum | 1 | 12 Jun 2009 07:16 am |
Could it be the timing belt? | mbmouse | Tech & Performance Forum | 4 | 12 Jan 2009 09:01 pm |
