ODD RADIATOR FAN PROBLEM
Old 24 Aug 2010, 12:54 pm
Default ODD RADIATOR FAN PROBLEM
Howdy all, Ive got a radiator problem that I cant seem to find a solution to by searching through the forums, here it goes,
I recently found my fan was only running when the ac was on so I wired it up and checked it, it was burnt up on either high or low,I dont know which is which?, I replaced the fan motor and now the fan runs all the time, what would cause it to run all the time? Im guessing something has went bad letting it run continuously and thats what burnt the brushes up on the first one, any ideas as to where I should begin? Ive swapped the relays around and no luck, help me out fellas
Old 24 Aug 2010, 01:50 pm
Default Re: ODD RADIATOR FAN PROBLEM
Your low speed was burned out. Only the high speed fan will come on with the a/c, so the high was working fine.
You may have a short somewhere in the fan wiring, or there may be an internal fault in the PCM supplying constant power to the fan. The PCM is what controls the fan speed through the two relays.
-Chris
Old 24 Aug 2010, 11:13 pm
mdfrodolives's Avatar
Maybe your low-speed fan relay is faulty, and stays open all the time.
Tim
Old 25 Aug 2010, 07:23 am
It sounds like its running on high anytime the key is on, its pretty loud and theres no change in it when I turn the AC on, so should I just change both relays and if its not that assume its the PCM? is there a sensor anywhere that tells the fan to come on? I unplugged the temp sending unit and the gauge quit working and high temp light came on, Oh and BTW its throwing a code PO481 Cooling fan relay 2 control circuit, anybody seen that one before? thanks
Old 25 Aug 2010, 07:40 am
From PT Do-It-Yourself.net:
Radiator fan operation is controlled by the Powertrain Control Module (PCM) with inputs from the temperature of the coolant, which is sensed by the coolant temperature sensor, and vehicle speed, which is measured by the vehicle speed sensor. The PCM turns on the fan through either the high or low speed fan relay.
P0481 - High Speed Fan Relay Control Circuit - An open or shorted condition detected in the high speed radiator fan relay control circuit.
Possible causes on the 2005 model year and earlier include:
High Speed Radiator Fan Relay Operation
Fused Ignition Switch Output Circuit
High Speed Radiator Fan Relay Resistance
High Speed Rad Fan Relay Control Circuit Open
High Speed Rad Fan Relay Control Circuit Short To Ground
PCM
Possible causes on the 2006 model year and later include:
Fused (B+) Circuits
Ground Circuit
High Speed Rad Fan Control Circuit Shorted To Battery Voltage
High Speed Rad Fan Control Circuit Open
High Speed Rad Fan Control Circuit Shorted To Ground
Radiator Cooling Fan Module
Totally Integrated Power Module
This is not a DIY repair. Unless you have a DRB III scan tool, multi-meter diagnostic manual and the experience to use all three, see your dealer.
Old 25 Aug 2010, 07:50 am
yup thats way over my head, thanks man that answered alot of my questions
The radiator fan fix 03PTMOM Tech & Performance Forum 26 25 Sep 2014 01:02 pm
2001 radiator fan problem koor Tech & Performance Forum 14 23 Aug 2010 06:47 pm
Radiator fan problem moparman3 Turbo Performance 0 29 Oct 2009 08:23 am
radiator sandylolee General Turbo Discussions 0 04 Jun 2009 12:59 pm
Radiator 4b316 Tech & Performance Forum 3 26 Dec 2008 05:56 pm
