Question regarding noise at 40 mph and above
Old 25 Aug 2010, 03:37 pm
Default Question regarding noise at 40 mph and above
Greetings all. I just purchased a very clean 2006 PT Cruiser Touring Edition with 66k miles and an automatic transmission. It's a great car and like it very much. I did notice something though that gave me pause. When driving at speeds at 40mph and above, I notice a faint whirring sound that becomes more pronounced when veering to the right but not so much to the left. Once the car drops to below 40mph the sound fades away. This doesn't happen all the time but seemingly more often than not. Have any of you encountered this before? If so does anyone have any ideas as to the cause? I don't think it is tire noise as it seems to be coming from the engine. Thanks for any wisdom you can share!
Old 25 Aug 2010, 03:48 pm
Default Re: Question regarding noise at 40 mph and above
Welcome to the forums.
Does it groan when you turn at lvery low speed, as when parking?
Check your Power steering fluid level - on left behind radiator - it gets filled with ATF + 4.
Old 25 Aug 2010, 04:19 pm
Many thanks for the quick reply quicksilverdon. No groans when turning at low speeds or when parking. Just the whirring sound at 40mph +
Old 25 Aug 2010, 04:36 pm
This might have nothing to do with it but when I first bought my PT down to Florida one of the first trips was down the parkway to the airport. I heard this noise as speed that drove me buggy trying to figure out what it was. Turned out to be the wind noise around the antenna. I usually had the stereo loud enough not to hear it but I had picked up visitors at the airport and had the stereo off.
A shorty chrome antenna took care of that.
Old 25 Aug 2010, 05:01 pm
Thanks Crewzin as well for your reply. If it weren't for the sound becoming more noticeable while veering to the right the scenario you describe could be a possibility. Did you notice this at the same speeds I mentioned, 40mph +?
Old 25 Aug 2010, 05:18 pm
I wasn't watching the speed, but the parkway is posted at 70 for most of the way. It did go away at certain speeds and didn't notice if it went away while turning as the turns are in slight curves and not really a turn.
Old 25 Aug 2010, 07:06 pm
Let's eliminate the tires as a possiblilty. A tire noise from the front could sound like it's coming from the engine area and would explain why the sound gets more pronounced when you veer/turn.
Rotate your tires and see if the noise transfers to the back of the car.
-Chris
Old 27 Aug 2010, 02:33 pm
Thanks everyone for your replies. I've had the car checked out and it seems the left wheel bearing needs replacement. The car only has 67K miles on it so I'm wondering after how many miles have any of you had to have the wheel bearings replaced?
Old 27 Aug 2010, 02:59 pm
Someone just posted in the: Wheel Bearing Poll, 190,000; NEVER!!!!
Old 27 Aug 2010, 03:16 pm
Here's some reading for you if your really interested ......
Poll: Wheel Bearing Replacement
Poll: Who's NEVER replaced their Wheel Bearings
Engine noise question Frugalfart General PT Cruiser Discussions 13 17 Jul 2010 01:33 pm
QUESTION: FRONT END NOISE TorontoPT2 Wheels, Tires, Suspension 5 25 Jun 2008 10:55 am
paint and noise question... new to forum ijoe General PT Cruiser Discussions 7 27 Jul 2004 04:38 pm
Air Bag Suspension Noise Question ptcruzin42 Wheels, Tires, Suspension 0 30 Oct 2003 07:49 pm
question on wind noise from side windows comPuTer General PT Cruiser Discussions 14 03 Sep 2003 09:12 am
