Autolite XP Iridium Plugs - Good?
Old 26 Aug 2010, 08:53 am
falconut's Avatar
Default Autolite XP Iridium Plugs - Good?
I originally installed some NGK V-Groove plugs recently, but I just don't seam to be getting as good of gas mileage as I was previously. I used to be able to get around 300 miles to my tank and now it seams that I'm only getting in the low to mid 200's.
I'm considering getting the Autolite XP Iridium plugs from Auto Zone. I was considering getting either platinum or double platinum, but found the Autolite Iridiums for not much more, plus there's a rebate. Just figured I'd check to see if anybody has used them.
Also, I read an article about fuel mileage and it was saying that when he increased his spark plug gap by 20%, he got better mileage. So, for me this would mean if instead of gapping the plugs at 0.040, I would gap them at 0.048. Has anybody done this? My NGK plugs are gapped at 0.040, but my old Champion plugs were around 0.060 - 0.070.
Old 26 Aug 2010, 09:08 am
Dino's Avatar
Default Re: Autolite XP Iridium Plugs - Good?
I used the Denso Iridium power plugs gaped at .044 without a problem, in fact the PT runs great. And I seem to get on the high side of MPG of what the PT can offer which isn't great.
Old 27 Aug 2010, 02:48 pm
Matt42's Avatar
I use the Autolite Iridiums in both of my PTs and really like them. A lot. DO NOT gap them over .040! I have no clue what was going on with the larger gap for better fuel economy. That makes no sense at all. None. It would make the engine run worse. I run .038. My 04 with a 5 speed gets 24 to 26 around town, with AC on, but I am a miser driver.
I suggest using MSD wires, which are what I use. Do not change out the OEM coil unless it is physically damaged or otherwise bad. If you have to replace it, use another OEM coil. They are best.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Autolite Double or Single Platinum Plugs? falconut Tech & Performance Forum 2 08 Jun 2010 03:19 pm
iridium plugs??? DARK270 Stage Turbo Kits 28 17 Jan 2010 04:02 pm
Champion Iridium Plugs rszappa1 Tech & Performance Forum 5 06 Feb 2006 08:09 am
Iridium Plugs luvmypt Tech & Performance Forum 9 19 Jul 2004 12:16 pm
Denso Iridium Plugs gsharrock Turbo Performance 2 22 Jun 2003 09:09 am
