Power steering switch
Old 26 Aug 2010, 03:48 pm
Exclamation Power steering switch
Need help,can anyone explain the best way to chance out a bad power steering sensor switch on a 2001 PT.Pulling (Code P0551)witch shows bad switch.Also what power steering fluid to use.
Thanks,
Ed
Old 26 Aug 2010, 04:42 pm
Default Re: Power steering switch
Chrylser calls for ATF+4 in the power steering unit. Just had mine done. WARNING: VERY messy job. Steering fluid rushes out when you pull the old switch.
Old 26 Aug 2010, 05:29 pm
CREWZIN,
Thank you for the photo,do you now the best way to remove it,is it from underneath or from the wheel well.Is it possible you might have a write up on how to do it?
Thanks.
Old 26 Aug 2010, 06:10 pm
No, don't have a write up. You can only get it from underneath the car. Forget the size wrench but should be in a normal tool box. Don't forget it's a messy job.
Old 26 Aug 2010, 07:17 pm
Thanks Crewzin,
Will try in a day or two will let you now how I make out.
Old 29 Aug 2010, 06:18 pm
Like Crewzin says, it's a messy job!!! Just did it last week. It uses a 7/16 deep socket, and as you remove the sensor/switch, steering fluid gushes out, so have a quart handy to replace it. I'd also recommend doing it after it has sat for awhile, so that the gushing fluid isn't hot. Access is from crawling under just beneath the driver's door, and I hope you don't have huge hands. Good luck with it!!!
Power Steering Switch navydave Tech & Performance Forum 9 11 Jan 2011 11:04 pm
Power steering switch Franksredpt General PT Cruiser Discussions 2 06 Oct 2009 11:53 am
Power steering switch failure Sue Tech & Performance Forum 1 09 Jun 2009 11:00 am
Power Steering Switch souljha Tech & Performance Forum 3 13 Feb 2009 02:13 pm
Tranny Failed then Power Steering Switch? Sami_Girl_FL General PT Cruiser Discussions 22 19 Dec 2007 09:06 am
