Radiator Cooling fan
Old 27 Aug 2010, 02:52 pm
Default Radiator Cooling fan
I have an 06 Cruiser and I have had to replace the radiator cooling fan 2 times in the last 8 months.. What would cause the fan to keep going out? This is getting frustrating..
Old 27 Aug 2010, 03:19 pm
Default Re: Radiator Cooling fan
Bad brushes in the fan motor. You could have gotten hold of a bad (made in China) fan replacement, or maybe some sort of short in the wiring. Hard to tell unless you inspect the fan motor to see why it failed.
Probably one out of two of the people on this forum have had to replace the fan once (maybe a little less) but once it's changed the second fan usually lasts a long time. It's the original fan from the factory that burns out and has to be replaced. I replaced my OEM fan about 6 years ago.
Old 28 Aug 2010, 12:08 pm
Matt42's Avatar
-snip-
What CREWZIN said. Chinese replacement parts are hit and miss. Some are excellent. Some are horrible, Save your receipts, always. The replacement fan assembly I bought was made in Thailand and it has been very good.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
cooling fan no go on the low nealtotheking General PT Cruiser Discussions 10 03 Aug 2017 08:19 pm
Cooling fan... need help Jimmyo General PT Cruiser Discussions 4 06 Jun 2010 10:54 pm
Radiator Cooling Fans garyerrol Tech & Performance Forum 5 25 May 2010 06:37 am
Cooling Fan Mod AZ_IceMan Stage Turbo Kits 3 25 May 2005 04:07 am
