01 pt timing belt rubbing oil pump
Old 31 Aug 2010, 04:26 pm
Default 01 pt timing belt rubbing oil pump
Hi every one ,im new to the forum , i just bought a 2001 pt fom my brother that had an oil leak ,long story short the timing belt rubbed through the oil pump.what would cause this. he had the timing belt ,water pump and tensioner put on it 34k ago ,it has the mechanical tensioner on it ,could the tensioner be bad missaligning the belt, is there any way to set the alignment on the tensioner ,any help will be really appriciated
Old 01 Sep 2010, 02:44 am
Default Re: 01 pt timing belt rubbing oil pump
I don't see how that's possible because there's a rear timing belt cover in place between the belt and the oil pump. Of course, I've seen other things that I could swear were impossible!
-Chris
Daves Log - 2002 Head Gasket/Timing Belt/Water Pump DigitaL101 Tech & Performance Forum 28 09 May 2013 02:04 am
Where to buy Timing belt/tensioner/water pump KalSaint Tech & Performance Forum 4 24 Nov 2011 09:02 am
TIMING BELT AND WATER PUMP CHANGE?? mjb457 Tech & Performance Forum 20 03 Apr 2011 10:38 pm
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
