Automatic transmission filter / O ring
Old 01 Sep 2010, 08:19 am
Default Automatic transmission filter / O ring
I'm getting ready to change the automatic transmission fluid on my sister's 2005 2.4 L non turbo cruiser (74,000 mi) and wondering where I can get a replacement filter and O ring for the pan? I was looking over the procedure in my Haynes manual and it mentioned changing both. I've found a few replacement filters, but no O ring. Does that part really need to be changed? What are most people doing for a filter and is there any preferred filter for the ATF? Please keep your replies to filters and O rings. I know the kind of ATF has been discussed to death so we don't need to dredge that one up again. Thanks guys!
2005 2.4L Non Turbo
Old 01 Sep 2010, 05:01 pm
Default Re: Automatic transmission filter / O ring
Done it twice. 2001 na and my 2004 diet. Used the "kit" from both Autozone and advance. Both came with RPL o ring and a rubber pan gasket. RTV would work as well on the pan gasket. Remember the torque on the pan bolts is way light like 15-20ftlbs. Far less than even spark plugs. Too tight and youll squish the gasket out and cause a leak
Old 01 Sep 2010, 09:58 pm
So, with another few hours of digging, I think I answered my own question. Wix makes a a transmission filter for the PT Cruiser (Wix part # 58934). You can buy it on Amazon for $11.95.
2005 2.4L Non Turbo
Old 01 Sep 2010, 11:08 pm
cruserdad1976's Avatar
auto zone---ORileys Pep Boys they all sell them as does most CHrystler dealers
Automatic Transmission Pan With Drain Plug Matt42 Tech & Performance Forum 3 18 Aug 2010 11:31 pm
Reliability-Manual vs. automatic transmission pstar General PT Cruiser Discussions 8 29 Mar 2010 10:36 pm
After Market Automatic Transmission Cooler pnwptowner Tech & Performance Forum 0 02 Feb 2010 01:43 am
Help! How to drain and refill automatic transmission? crooner44 Tech & Performance Forum 7 11 Jun 2009 01:42 pm
using second gear with automatic transmission? gfx Tech & Performance Forum 2 18 Jul 2004 02:24 pm
