Possible Head Gasket Failure question
Old 04 Sep 2010, 07:35 pm
oldorange's Avatar
Question Possible Head Gasket Failure question
So it went back to the mechanic and after many hours they are telling me it may very well be the head gasket, even though the traditional tests did not indicate that problem.
1. Has anyone else had this occur? overheating when the tests said negative and it was eventually resolved to the head gasket, or head or block?
2. Is it possible that it could still be the head or block too?
3. Could a mechanic MASK a head or block failure temporarily do you think?
you see this is a recent purchase and is being repaired under the sellers word and 3 month warranty and on his own dime for me.
My 2003 PTOS... ...Will it ever STOP Squeaking & Creaking???!!! And 21 MPG, what's up with that?
Old 04 Sep 2010, 07:50 pm
zip zip is offline
Default Re: Possible Head Gasket Failure question
If it is, be glad you're not paying for it........I got an estimate on mine.......OUCH!!!
Old 07 Sep 2010, 09:41 am
1) Not that I know of
2) - Block is almost never at fault - the head MAY be warped
3) - Not that I know of, and that's be stupid, because the problem (I assume it overheats) will still be there until real problem is fixed.
Head gasket ? bds02pt Tech & Performance Forum 33 29 Sep 2011 08:30 pm
head gasket how to tell if bad BeagleDad Tech & Performance Forum 18 18 May 2010 09:53 pm
Head gasket failure at ~11,000 miles 2007 General PT Cruiser Discussions 21 27 Feb 2009 03:21 pm
head gasket broadleaspeaking1 General PT Cruiser Discussions 1 27 Mar 2008 05:44 am
Head Gasket Kirby Stage Turbo Kits 7 04 Nov 2003 10:59 pm
