Adjust the speedometer?
Old 06 Sep 2010, 03:38 am
Question Adjust the speedometer?
I was just wondering... Is there were a way to adjust the speedometer?
I was considering some new wheels/tires, but they are not an exact match, so the speedometer would not be accurate. Since this is all computer controlled, can it be adjusted?
If not, can the gear/sensor/etc in the transmission be adjusted or replaced to compensate?
Old 08 Sep 2011, 01:12 am
Question Re: Adjust the speedometer?
Bumping this...
Is there any Chrysler experts out there than know if the speedometer can be adjusted to compensate for a change in tire size?
Can the PCM be reprogrammed? Can a gear be changed on the cable? etc?
Thanks!
Old 09 Sep 2011, 12:48 am
Default Re: Adjust the speedometer?
Originally Posted by Calab View Post
Bumping this...
Thanks!
Can't be done. You can compensate with tire size, though.
Old 09 Sep 2011, 02:15 am
It's really not that big a deal. I went wider, with bigger wheels and tires. I took my PT out for a drive with my GPS on to monitor the accuracy and my speedo is exactly 2mph slow. 2mph?? I really don't believe I'll worry about that....
Tags
speedometer, wheels
Lever to adjust seat angle broken Edwin Astacio Interior Accessories Forum 12 18 Nov 2009 12:38 am
speedometer petiecruiser Tech & Performance Forum 1 12 Oct 2009 08:14 pm
speedometer 4SPEED Tech & Performance Forum 2 29 Sep 2006 05:00 pm
Speedometer is off by 2 mph. Knucklehead Tech & Performance Forum 10 31 Aug 2004 02:46 am
