code after timing belt change
Old 06 Sep 2010, 07:45 am
Default code after timing belt change
I just replaced a timing belt on '01 with 2.4L. Ran good for 1/2 mile then engine died. Now engine runs rough (sometimes dies) and has set code P0140. Nothing visibly wrong with O2 sensor or wiring. Any ideas?
Checked for broken/damaged wires, hoses, etc from belt change, all ok so far.
Old 06 Sep 2010, 10:13 am
chigger_ns's Avatar
Default Re: code after timing belt change
At times people change the rear o2 sensor only and the code may or may not disappear and it may reappear quite fast too indicating either the cat is faulty or the 02 sensor before it is faulty or there is a combination of those two devices being faulty or the exhaust system has a fault or the engine requires serving etc.
Also check the exhaust for leaks.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
when to change Timing belt ? Ctown General PT Cruiser Discussions 13 18 Aug 2014 05:40 pm
Timing belt change, then CEL code for oxygen sensor? p_ridge_pt Tech & Performance Forum 1 05 Jul 2010 05:15 am
Timing Belt Change? tgibeau Tech & Performance Forum 10 07 Jun 2010 10:21 pm
Timing belt change turbomangt General Turbo Discussions 31 19 Jan 2009 04:48 pm
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
