How To Adjust Idle??
Old 06 Sep 2010, 04:22 pm
Default How To Adjust Idle??
I changed the spark plugs today and the idle still sits at about 800 rpms and runs a bit rough. When I took off the plastic cover over the throttle linkage, both cables looked a bit slacky for a better work. What is the idle RPMs supposed to be at, and how do I adjust the idle??? Is there a video that shows how to adjust it?
Old 06 Sep 2010, 06:26 pm
Default Re: How To Adjust Idle??
Did you also change the plug wires, the wires are problematic on the PT? Plugs gapped at .040?
Old 06 Sep 2010, 06:31 pm
Yes I changed the wires and the plugs were Bosh with the 4 pronged that do not need gapping.
Old 06 Sep 2010, 08:50 pm
xwing777's Avatar
The idle is controlled by the PCM. I have a predator programmer and can change it through it. 800 RPMs sound a little low though i think its around 900 normally. You may try unhooking the battery for a bit and reattaching it to reset the computer.
Old 06 Sep 2010, 09:17 pm
I have the positive unhooked when I changed the spark plugs. I will try to unhook it again. This is the whole reason my other car is an RV with a Cummins that is mechanical. And I will be selling this PT soon and buying a peterbilt truck with a detroit. Easier to work on.
Old 07 Sep 2010, 07:45 am
Wow, if you think the PT is to hard for you to work on, you haven't been looking or searching around very much. Good luck with your peterbuilt with a detroit, whatever that is.
Adjust the speedometer? Calab Tech & Performance Forum 3 09 Sep 2011 02:15 am
Low idle sconnors11 General PT Cruiser Discussions 1 11 Aug 2010 09:50 pm
Lever to adjust seat angle broken Edwin Astacio Interior Accessories Forum 12 18 Nov 2009 12:38 am
ruff idle at idle only? KRNFIRE General PT Cruiser Discussions 16 23 Jan 2009 09:08 pm
Idle with S1 turbomangt Stage Turbo Kits 10 10 Mar 2005 05:39 pm
