help,headlight problem :(
Old 07 Sep 2010, 05:51 am
Unhappy help,headlight problem :(
Hi,i have a 2006 touring edition..few days ago driver side headlight bulb(low) went off..i replaced the bulb but it didnt work..i checked the fuse box and they are ok..i think the problem is related with wires..anyone knows how to replace the wires or any ideas to fix the problem_? thx..
Old 07 Sep 2010, 06:27 am
Default Re: help,headlight problem :(
You just don't replace wires, you replace the wiring harness and you really don't want to take on that job.
First get a multi-meter and check the voltage at the bulb end to see if your getting power to the bulb. Then go from there.
Old 13 Sep 2010, 07:08 pm
i took my car to an auto electrician,they told me that there is a problem with the wires.tomorrow they will try to fix it..
Old 13 Sep 2010, 07:21 pm
Wow, in your other thread your asking about the A/C and took it to a shop for their expensive opinion and now your doing the same with the wiring harness of the headlights. Why even ask here before taking to the shop?
The compressor is usually the last thing to go and so is the wiring. Lods of things to go wrong before that.
Good luck.
Tags
bulb, fuses, headlights, wires
Headlight mod... CYCLONE_06 Exterior & Interior Styling 20 11 Mar 2011 02:56 am
Headlight Problem Madturtle Tech & Performance Forum 2 04 May 2009 08:05 pm
HEADLIGHT ANTI FOG KIT?? mjb457 General PT Cruiser Discussions 9 11 Mar 2009 07:20 am
Headlight Problem jmack General PT Cruiser Discussions 21 23 Nov 2007 05:58 pm
Headlight ty97206 Exterior Accessories Forum 1 24 Sep 2007 02:18 pm
