Getting Extremely Tight PLUGS Out GT???
Old 07 Sep 2010, 06:00 am
mjb457's Avatar
Default Getting Extremely Tight PLUGS Out GT???
Ok now on my GT plugs are easy to get to but wow tight! My brother said to remove boot and soak with WD40 overnight? They will loosen eaier?Also use never-seize..What are best plugs & gap also?? Thanks MJB
Old 07 Sep 2010, 06:23 am
Default Re: Getting Extremely Tight PLUGS Out GT???
Just a couple drops of the WD-40 overnight hopefully will loosen the plugs. The name f the stuff to put on the threads of the new plugs is called Anti-seize. The head is aluminum and the plugs are a different material and when two different metals are together a long time they can almost become mated. The Anit-seize helps prevent that.
As fa as plugs and wires, please go to the top of the forum and click on the "search" word. Put "plug gap" into the search category and you'll see loads of threads talking about the ignition parts.
Old 07 Sep 2010, 08:35 pm
mjb457's Avatar
Crewzin ,,done,,easy on the Turbo..just let in sit an hour with a bit of WD40 .runs great,,gaped .40..champions(not platinums) next step Diablo Prediator !MJB
Old 07 Sep 2010, 08:38 pm
Don't know too much about the Prediator but I hear it's as good as Stage 1. Good luck.
Old 08 Sep 2010, 05:47 am
Hope you also put dielectric grease on the plug boots and put in new wires that weren't stock ones...
Old 08 Sep 2010, 01:19 pm
mjb457's Avatar
yep and Taylor wires(red) where did you get your strut bar? thanks Mjb
E3 plugs for my PT? Dino General PT Cruiser Discussions 34 03 Mar 2010 11:48 am
plugs dweebluver General PT Cruiser Discussions 1 24 Jul 2008 04:17 pm
PLUGS HELP:?? mjb457 Tech & Performance Forum 9 11 Aug 2007 01:33 pm
Plugs kennybopaloo General Turbo Discussions 15 24 Dec 2004 03:43 am
Grill from 'Tight-Products' 1lowufo Exterior Accessories Forum 1 27 Nov 2004 06:13 pm
