who carries HOAT antifreeze coolant in central nj
Old 07 Sep 2010, 08:36 pm
Default who carries HOAT antifreeze coolant in central nj
i looked at
autozone
pepboyes
local parts stores
advance auto,
how come its so hard to find???
anyone know where to get the zerex g05
Old 07 Sep 2010, 08:42 pm
Matt42's Avatar
Default Re: who carries HOAT antifreeze coolant in central nj
Try NAPA for the Zerex. You may have to ask at the counter. Try calling the Zerex distributor. Failing that (gasp) the Chrysler dealer will have it. They will be very proud of it, and price it accordingly. But after a while, you will stop wasting gas looking for it. And using it will save your radiator.
Also, I discovered there are two types of HOAT! There is a yellow version that is good for years through 2002. The purple or pink version is for 2003 and up. The dealer will have both, again, at a price.
Believe it or not, here in the Phoenix area, in a state that's only been a state since 1912, the dealer we go to has been a family business since 1927. So they take their responsibilities to their customers seriously. And those responsibilities seem to include not overcharging for stuff. Who'd'a thunk it?
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Last edited by Matt42; 07 Sep 2010 at 08:49 pm. Reason: I am colour blind, I think. Pink = purple to me.
Old 07 Sep 2010, 10:30 pm
xwing777's Avatar
I agree, i got mine at NAPA also. But i called and asked if they had it, the guy said "no, but we can order it just stop in and prepay" so i go in and told a different guy i needed to order it. After a few minutes of explaining what kind and why...he said "oh you can use dexcool, its the same thing" He then takes me to the back to prove it by showing me the label and guess whats on the shelf......4 gallons of the zerox! I picked up 2 gallons and left
So IF they say they dont have it, make sure to go in and confirm this yourself as they probably do have it instock or in my case they were to dumb or to lazy to really check it.
Old 08 Sep 2010, 05:39 am
Got mine at Napa also - there were 2 zerex - 5 & 3(?) - they looked it up and gave me the 5 (was a couple bucks cheaper per gallon).
Old 08 Sep 2010, 09:17 am
Mal Mal is offline
In South Jersey both NAPPA and Cown carry Zerex G-05 which as I understand it is exactly the same (HOAT) coolant as the more expensive and prettier stuff that Chrysler sells. I would avoid Dexcool though it has a much worse rep than it deserves due to some bad plastic gaskets GM used in some of their V-6's and never really took responsibility for.
The G-05 is really hard to see in the PT overflow. You can give the overflow a shake or add a little food coloring in your choice of colors to help you out. Some food color will turn in the heat and some won't. There are also commercial coloring agents that won't turn but you pay for them.
Old 24 Oct 2010, 08:35 pm
In Philly Auto Zone has it as does WalMart. Also remember if you are being so competent to search for the correct and best anti-freeze,don't negate your efforts and mix with TAP water!! Use ONLY distilled water in your cooling system(mineral free). It's very cheap and available in food stores.
Read the best article I've read in recent history on coolants. Go to "MOTORMAGAZINE.COM" and read the article in the AUG,2010 edition. This mag/site is the best source of technical articles around.
Old 25 Oct 2010, 10:04 pm
Matt42's Avatar
Waaaaaggghhh!
I thought that I was being a little over the top in my explanations of the differences between coolants and why people ought to seriously consider using the right HOAT coolant in their PTs. Then I read the article. Here's the link, by the way: MOTOR Magazine Article | MOTOR Information Systems
All things considered now, I think even more so that I have made the right decision.
--I get my PT Cruiser and Town & Country coolant from the Dodge-Chrysler dealer to prevent ruining a $400 radiator and maybe a $2500 engine.
--For many years, I have bought the coolant for my truck from the Cummins dealer to prevent ruining an $800 radiator and a $10,000 engine.
The cost of replacing a PT Cruiser water pump with bad seals ruined by DexCool more than outweighs the extra $10 for a gallon of HOAT from the dealer. Another 99 cents for a gallon of distilled water is also a good idea, as said above.
Old 25 Oct 2010, 10:11 pm
Strange as it may seem, in my neck of the woods the the dealership actually had the lowest price on H.O.A.T about 14 bucks for the gallon.
NAPA and the rest were a good deal more expensive.
I agree with Matt42, buy the right thing and use it with confidence.
Don't pinch a penny now and spend a whole lotta dollars later.
Old 26 Oct 2010, 08:45 am
I use a piece of wooden dowel I stick in the overflow tank to tell me the coolant level....
Which antifreeze? OneBadCruiser Tech & Performance Forum 16 02 Mar 2013 06:18 pm
antifreeze? fattmann Tech & Performance Forum 3 04 Jul 2010 12:29 am
Another Antifreeze-Coolant Thread Matt42 General PT Cruiser Discussions 4 01 Nov 2009 03:27 pm
PH level of HOAT Coolant yaschief Tech & Performance Forum 2 13 Aug 2008 01:01 pm
