2004 Spark Plug Change
Old 08 Sep 2010, 06:49 pm
Default 2004 Spark Plug Change
I am seeking a girls guide to changing spark plugs. I am determinded to take care of my cruiser myself. I learned how to do the oil, I just need to learn spark plugs. ASAP too. If anyone can help. When I say girl guide I mean very detailed, loads of pics, and a lingo I can understand. I am talking "this bolt" "that bolt" EASY!
it is a 2004 basic model, no turbo, automatic.
Old 08 Sep 2010, 07:11 pm
Default Re: 2004 Spark Plug Change
There is a sticky in the performance section that is a pretty good step by step guide. Don't remember if it has pictures tho. Maybe do a search for Spark Plugs.
Welcome Cruiser!!!
Old 08 Sep 2010, 11:37 pm
cruserdad1976's Avatar
I have to say that changing the plugs on a PT is about as easy as it gets
you will need a few basic tools
I don't remember the sizes but when you look at your engine the air intake has like 4-5-6 little bolts holding it in place you remove them
then the air intake is lose
loosed the clamp and wiggle it around ( I usually do not remove mine)
the plugs are deep so you will need a "REAL" spark plug socket and a good extension and a 3/8 ratchet
pull the plug wire or boot off the plug
put your socket on the plug
and remove it
now when you put in new one
1 ALWAYS gap them no matter what the auto parts store tells you get a tool and gap them to make sure they are correct
next anti seize lube the plugs
put some type of grease on the inside of the plug wire
I don't torque my plugs but some will say you need to but then you will need a tork wrench
If you are changing plugs then I would also change the wires they have to come off the plugs anyway
just remember 1 at a time take it off put the new one exactly where the ole one was
there is a re3ally good write up on here complete with pics btu this will get it dont
Dont over think it it si really pretty easy if you get a plug that is to tight to get out squirt some WD 40 in the hole and let it sit for about half a hour
don't make it harder than it is
Old 09 Sep 2010, 01:26 am
Freezinghot's Avatar
The N/A is actually fairly difficult to most engines ive worked on. Most of which are old cars , where the plug is right on top and you can replace blindfolded
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 09 Sep 2010, 01:37 am
Here's your guide ...
Spark Plug Guide
Old 09 Sep 2010, 08:01 am
some how I KNEW Crewzin would come through
freezinghot Id have to agree if we were talking about a 79 Chevy 350 but on a lot of the newer cars you cant even see the plugs
Old 09 Sep 2010, 08:26 am
lilooetruiser,
On the spark plug changing guide, forget all you read about the EGR pipe in the back of the upper manifold. They stopped putting them on in about 2003. It was one of the hardest parts of the job anyway because it involved two separate size bolts and was in an awkward place to got to.
Tags
spark plugs
spark plug wire change help demon666 Tech & Performance Forum 6 19 Jun 2010 09:08 pm
Spark plug change interval DJmart Tech & Performance Forum 4 12 Jul 2008 07:06 pm
2006 non turbo spark plug change samson77 Tech & Performance Forum 9 06 Feb 2007 12:36 am
Spark plug change PtCruiserDan General PT Cruiser Discussions 5 22 Mar 2006 06:22 pm
spark plug change Joe General PT Cruiser Discussions 9 29 Oct 2003 12:21 am
