Custom Wheels
"Seafoam TRANS TUNE" on a automatic Transmission?
Old 10 Sep 2010, 12:44 pm
RedPT07's Avatar
Default "Seafoam TRANS TUNE" on a automatic Transmission?
Does anyone has been used "Seafoam TRANS TUNE" before change the fluid to clean residue on transmission?
They claimed:
TRANS-TUNE is NOT a stop-leak or super lubricant additive and is safe to use because it does not swell or harm seals in any way..
I read that Chrysler do not recommend use any cleaner, additive to trans unless ATF+4.
Thanks,
RedPT07
Old 10 Sep 2010, 01:00 pm
Default Re: "Seafoam TRANS TUNE" on a automatic Transmission?
I'm not sure why you want to use anything other than ATF+4, when the manual says not to use anything??
Old 10 Sep 2010, 01:11 pm
RedPT07's Avatar
Because I had erratic shift on my 2005 Malibu Ls since he has 45K miles and I did the 1st Fluid change at 50K and continous doing the same and at 75K miles I used half can of SeaFoam TRANS TUNE before the 2nd Fluid change and problem solve, that was 4K miles ago and no more problems.
I just want to know if anybody has been using it? to be sure does not harm 'Chrysler' Transmission.
SeaFoma Guys said:
TRANS TUNE is a 100% Petroleum product comprised of three specific oils, blended in just the right proportions to SAFELY clean varnish deposits in transmission, power steering and hydraulic pump components. TRANS-TUNE is compatible with all commonly used petroleum and synthetic based hydraulic fluids used in automatic transmissions, power steering systems, marine transmissions, agricultural equipment and industrial hydraulic lifts.
TRANS-TUNE reduces rough or erratic shifting by dissolving varnish that contaminates transmission valve bodies, bands, governors, pumps and passages. TRANS-TUNE makes the perfect system flush for transmissions, power steering and hydraulic pumps, removing damaging moisture and deposits that impair system performance.
Old 10 Sep 2010, 01:59 pm
I'll say that the mechanic that did my trans flush used a can of BG cleaner before the ATF+4 change. I wasn't having any problems but it was part of the cost of having it flushed.
BG Products, Inc.
2000 PT. Original Owner, 115,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
NY Times article: http://www.nytimes.com/2008/10/30/au...30vintage.html
Old 10 Sep 2010, 08:18 pm
RedPT07's Avatar
Crewzin is good to know you have experience applying transmission residue cleaner.
I'm thinking about to put "Seafoam Trans Tune" but I'm a little worry by the Chrysler picky guys with their transmission recommendations.
Let see....
Old 10 Sep 2010, 08:38 pm
It was the Chrysler tech who used it as part of the flush. I didn't ask for it, he just ran it through the flush machine before the new ATF fluid. Do't know anything about the Sea Foam.
Old 10 Sep 2010, 11:44 pm
cruserdad1976's Avatar
well I am a big time sea foam fan i run in in all my cars in the fuel and in the oil and have for a long time
now with that said I had a weekend set aside to do the tranny service on mt 06 PT filter and fluid so i added a can on a Friday morning thinking I would run it that day to work and back which is 195 miles and then drop the pan when i got home I did add the sea foam but things didn't work as I planned and it was in there for about 4 weeks don't know if it helped but that was 50,000 miles ago so i guess it did not hurt-- but like anything everyone's car is different and we all treat them different I always put a quart of Lucas in on every oil change but i know guys who will say man i put that in and it gummed up my motor
Old 13 Sep 2010, 01:37 pm
RedPT07's Avatar
Thank guys for your personal experience.
I did it this weekend, add more than 1/4 can of Seafoam transtune, drove 20 miles, did the filter change and fluid (+/- 4.75 quarts) and I've driven for 100 miles and car run great.
I did Seafoam to engine 1/3 intake, 1/3 oil (previous oil change) & 1/3 gas. White smoke = O.K.
I'm a big fan of Seafoam also.
Old 13 Sep 2010, 01:44 pm
For future reference, most manufacturers specifically recommend against the use of any additives in any of the fluids. They recommend their own brand fluids only.
But Seafoam is a fantastic product and I've used it myself with very pleasing results.
-Chris
Old 21 Sep 2010, 09:40 am
RedPT07's Avatar
heifetz has you been using TRANSTUNE on you transmission?
2002 Pearl Almond Limited Pt "Custom Route 66 " Edition rt66pt Classifieds: For Sale/Trade 59 03 Mar 2013 11:49 pm
Part number for "PT" door emblems on 2008 Dream Cruiser 5 gpr75 General PT Cruiser Discussions 6 16 Jul 2010 12:15 pm
Transmission linkage "temporarily fixed" PTmodrod Tech & Performance Forum 0 09 May 2008 08:07 am
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
