cooling fan r.p.m.
Old 11 Sep 2010, 08:05 am
Cool cooling fan r.p.m.
ok i have a 2001 cruiser nontubo i have replaced all the cooling parts that mite make it over heat all but the fan it runs on high & low but the r.p.m.s of the fan are the same is this correct .thanks for the help.
Old 11 Sep 2010, 08:58 am
Default Re: cooling fan r.p.m.
If your saying the high and low fan run at the same speed, how do you know you have both speeds?
Never mind that, you don't have them both. There's a heck of a difference between high and low speed. When the low is on you actually have to look to see if it's spinning if the engine is running because it's that quiet. With the high speed, there's no dought that it's on, the air rushing around together with the slight noise of the fan motor is way above the noise of the engine. If yours isn't like that, most likely the high speed part of the fan is burnt out.
Old 11 Sep 2010, 09:34 am
thanks for the help! yes the fan comes on with ac. if i cut the ac off the fan will come on as it gets hot but the rpms are the same.and i still run hot in stop & go traffic only . if the high speed part is burnt out will it still run at low speed in high speed mode???? as it gets hot. thanks.
Old 11 Sep 2010, 09:38 am
That I don't know. The question was never raised before.
Old 11 Sep 2010, 09:46 am
thanks for your help. i need to just shoot this cash pit.
Old 13 Sep 2010, 12:26 pm
If your fan comes on with the a/c it's not your high speed fan that's burned out. Only the high speed fan will come on with the a/c.
-Chris
cooling fan no go on the low nealtotheking General PT Cruiser Discussions 10 03 Aug 2017 08:19 pm
Cooling fan... need help Jimmyo General PT Cruiser Discussions 4 06 Jun 2010 10:54 pm
over cooling christopher760407 Tech & Performance Forum 2 14 Mar 2010 09:55 pm
A/C not cooling at all bigjoe1651 Tech & Performance Forum 5 10 Oct 2009 02:42 pm
Cooling Fan Mod AZ_IceMan Stage Turbo Kits 3 25 May 2005 04:07 am
