Hissing sound
Old 12 Sep 2010, 11:45 am
Default Hissing sound
I have a 2005 2.2 deisel cruiser and am experiencing a loud hissing sound when the car is under load (ie acceleration) on one occasion it went into limp mode.
Can anyone please suggest a cause
Old 12 Sep 2010, 12:18 pm
Default Re: Hissing sound
Welcome to the forum.
They don't build diesels in the U.S. so a lot of us can just guess what it might be. It wouldn't be a turbo would it? There's a couple of pipes on the turbo models that have problems staying together with the clamps that Chrysler used and when they come apart they leak and sometimes sound like a hiss.
Old 05 Oct 2010, 04:39 pm
Sorry for not replying sooner - all fixed now.
It was the intercooler pipe which had a split at the back.
Replaced and all working ok.
Thanks
Old 05 Oct 2010, 04:59 pm
Ahhhhh, it was a turbo. Glad you found the problem.
Old 07 Oct 2012, 05:39 am
I'm currently in the process of replacing a split Turbo Hose on my PT Cruiser.
I purchased the part from Chrysler PT Cruiser parts and accessories from the PT Company after getting the infamous "unknown" Fault code P01A4.
It's really great, because they even provide you with fitting instructions which can be found here:
http://www.ptcompany.co.uk/Assets/pdfs/Turbo%20pipe.pdf
Every thing was going great, until I tried to re-attached to "C-Clip". When I took it off, apart from the fact that there isn't very much room to see anything, the general area was completely covered in oil due to the split pipe, so I can't even say as how it was attached in the first place.
The instructions are great apart from this part of the job
"To fit the new pipe, fit the C clip first and check itís in the correct position - the wire should be visible when you look inside the pipe if its correctly placed in the locating slots (It can fit either way up)."
Firstly it says "the wire should be visible when you look inside the pipe", the C-Clip is way too big in diameter to fit inside the pipe and secondly if you check out the pictures at the bottom you can clearly see it on the outside.
it then continues to say:
"(the rim around the pipe sits flush with the rim of the
intercooler - if itís not flush itís not pushed home enough"
If the C-Clip attached to the pipe it prevents it from sitting flush.
I'm kind of at the point where I don't even see what this C-Clip does and there is next to nothing on the internet information wise regarding it existence.
I called up the guy at ptcompany.co.uk and he wasn't sure and referred me to the guy who wrote the above instructions but I'm not getting a response from him.
Any help at all would be greatly appreciated! I'm at my wits end!
Thanks
Phil
sound not gone... superpug666 Turbo Wheels/Suspension/Handling 12 02 Jun 2010 07:36 pm
No sound Help please. demon666 Sound and Security Forum 4 17 Aug 2009 05:36 am
Hissing Noise - Please Help? Slowpoke Tech & Performance Forum 2 10 Dec 2008 05:13 pm
GRRRRRRR sound need help csd Tech & Performance Forum 9 05 Apr 2008 10:30 am
Wired for sound? CREWZIN Sound and Security Forum 14 23 Jun 2004 08:13 pm
