what does UIMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED mean?
Old 12 Sep 2010, 04:23 pm
Default what does UIMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED mean?
Had the tires rotated and brakes checked out. All was fine for a short while, then the ABS and TCS yellow lights came on. Also the little low tire indicator light. Searched this site and found how to check code (thank you very much) and found U1418 - UIMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED. What exactly does this mean? How do I fix it?
Old 12 Sep 2010, 04:52 pm
Default Re: what does UIMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED mean?
Don't know if this will help. Found two answers:
Set Condition:
The PCM gets an implausible signal over the CAN C circuit from the ABS Module. The circuit is continuously monitored. One Trip fault.
Possible Causes
VEHICLE SPEED SENSOR FAULT ACTIVE IN ANTI-LOCK BRAKE MODULE
CAN C BUS CIRCUIT SHORTED
CAN C BUS CIRCUIT OPEN
ABS MODULE
PCM
U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED
When Monitored:
With the ignition on, battery voltage between 9 and 16 volts, and engine run time greater than 3 seconds.
Set Condition:</B> The PCM either doesn't receive a bus message or receives an implausible bus message from the Anti-Lock Brake Module.
Possible Causes</B> CAN C BUS OPEN OR SHORTED CONDITION NO POWER TO ANTI-LOCK BRAKE MODULE — MODULE UNPLUGGED OR OPEN FUSE POWERTRAIN CONTROL MODULE (PCM)
</B>
Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES - DIAGNOSIS AND TESTING for diagnostic procedures and for further possible causes.</B>
Theory of Operation
The PCM receives:
- Wheel speed and wheel distance CAN bus messages from the Anti-lock Brake module.
- A/C Pressure, Ambient Air Temperature and Fuel Level CAN bus messages from the Body Control Module.
If everything was good before the work was done, I'd go everything that was done and look for some sort of wire or connection that might be loose or unhooked from the ABS sensors.
Received Hurst Shifter go-vair Turbo Performance 0 01 Sep 2004 09:20 pm
Anyone received a Stage 1 badge lately? GLH_TC 16V Stage Turbo Kits 4 07 Feb 2004 04:41 pm
WHAHOO...Just received my new tires hyracer Turbo Wheels/Suspension/Handling 6 12 Dec 2003 09:09 am
Received & Installed Stage I mvandale Stage Turbo Kits 13 01 Oct 2003 04:33 am
Has anyone received a Stage I yet? Dalite Stage Turbo Kits 27 26 Jul 2003 11:34 pm
