P0118 - Engine Coolant Temperature Circuit -WHERE IS IT?
Old 13 Sep 2010, 10:25 pm
oldorange's Avatar
Question P0118 - Engine Coolant Temperature Circuit -WHERE IS IT?
P0118 - Engine Coolant Temperature Circuit High Input (I found it but have two questions please......)
I have this error code
1.) can anyone say if the car should be driven while the check engine is on and it has this code?
2.) how do you clear such a code to see if the problem has cleared yet? ( Is removing the battery cable the only way if you dont have a code reader?)
thanks
matt
PS I saw something in another post about removing the negative battery cable and so after much searching for the battery, pulled the cable and am waiting a few minutes.
PS2 So that worked for the CEL and the code. I will have to drive it tomorrow and see if this is more than a connection to the ECT problem (it was a little loose, and I cleaned it too)
My 2003 PTOS... ...Will it ever STOP Squeaking & Creaking???!!! And 21 MPG, what's up with that?
Old 14 Sep 2010, 05:38 am
Default Re: P0118 - Engine Coolant Temperature Circuit -WHERE IS IT?
Yes, you can drive the car if the engine light is on. Depending on the code, you want to keep an eye on the temperature guage to make sure you don't overheat. When the fault is bad enough to hurt the engine the the light will be flashing on/off.
One of the mechanics on this forum says the engine light will go off by itself after so many cycles after the fault has been cleared. Most of us don't want to wait that long and clear it with the battery cable.
Engine Code P0740 Torque Converter Clutch Circuit ctsimonjr Feedback and Support 7 30 Sep 2014 09:40 am
empty coolant w/engine light? JSH General PT Cruiser Discussions 1 02 Oct 2010 06:34 am
coolant sensor circuit problems swordfish Tech & Performance Forum 1 15 Apr 2010 12:11 am
Temperature & Coolant Problem SRMarsh General PT Cruiser Discussions 7 13 May 2009 01:42 pm
The engine temperature Issue. hermtm2 General PT Cruiser Discussions 4 28 Dec 2007 05:17 pm
