2006 pt need help?
Old 16 Sep 2010, 11:51 am
Default 2006 pt need help?
Hi i a new to this site looks great seems like alot of helpful people... so here the problem most recently my pt cruiser not a turbo has not been running right and the check engine light came on did the code thing and this is what i gave me
P0132
the car has died a few time while idling
thanks in advance
Old 16 Sep 2010, 01:39 pm
Default Re: 2006 pt need help?
OBD-II Trouble Code: P0132 Oxygen Sensor Circuit High Voltage (Bank1, Sensor1)
code P0132 - Oxygen Sensor Circuit High Voltage is what Google found. IF you change sensors, use OEM instead of aftermarket, our PT's don't like aftermarket sensors.
Old 16 Sep 2010, 02:36 pm
Bank 1, Sensor 1
Old 22 Oct 2010, 09:19 am
I saw where you help this other lady with her pt cruiser. my pt is running slightly hot when i stop at red lights,train tracks and dive thru. it runs cool when i am driving. what could be the problem.
Old 22 Oct 2010, 10:55 am
The radiator fan cools everything when at idle and up to 35mph. After that, the fan shuts off and there's enoough air coming through the front of the car to keep it cool.
Your problem could be a number of things but the most likely it's the radiator fan. Probably the high speed brushes have worn away inside the motor. It can be rebuilt or a new motor bought or a whole new fan and assembly. But first you have to find out if the fan is coming on and blowing on high speed to cool down the coolant.
2006 pt help fromphoenix General PT Cruiser Discussions 7 20 Jul 2010 10:36 am
2006 pt help fromphoenix General PT Cruiser Discussions 10 18 Jul 2010 02:22 pm
2006 PT GT KC2IFR General Turbo Discussions 1 05 Sep 2009 09:03 pm
2006 CHRYSLER PT CRUISER AUTOMATIC FACTORY WARRANTY, VERY CLEAN CAR (2006 CHRYSLER PT skylight craigslist 0 15 Jul 2007 01:10 am
My 2006 BeachBum General PT Cruiser Discussions 17 20 Jun 2007 07:25 am
