2004 PT with 300/2074 codes
Old 17 Sep 2010, 11:36 am
Default 2004 PT with 300/2074 codes
non turbo runs good then will develop a bad misfire on mainly cyl 4 but 3 very occasionally --runs poor for a minute or so then smooths out and runs good--HELP!!!!!!
Old 17 Sep 2010, 11:49 am
Default Re: 2004 PT with 300/2074 codes
P0300 is a multiple cylinder misfire.
....could be caused by the other code.
P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH FLOW/VACUUM LEAK
When Monitored: Engine Running, during all drive modes.
Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM
at closed throttle.
POSSIBLE CAUSES
VACUUM LEAK
HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
MAP SENSOR
HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT
HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT
PCM
TP SENSOR OPERATION
HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
TP SENSOR
HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT
HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Codes, Codes, everywhere there's Codes Neen Tech & Performance Forum 6 21 Nov 2008 07:59 pm
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
obd codes camarillogolfer General Turbo Discussions 5 06 Aug 2004 11:10 am
