CODE P0441 AGAIN
Old 17 Sep 2010, 03:46 pm
mjb457's Avatar
Default CODE P0441 AGAIN
Ok my non turbo 2003 threw a check engine light today.( it rained here heavy last night-PT was outside( 2 months ago-in July 13th same code) 2500 mile ago.....( I was driving in heavy rain when it came on) I did change gas cap since July... is it a rain issue? something shorting & getting wet..this time I drove about 15miles after the rain-the next day so it was dry out. I eset light by disconnecting negative battery terminal for 10 minutes..any ideas,,I dont want to waste time & money on unneeded parts.85K miles now.Thanks MJB
Old 29 Sep 2010, 03:51 am
chris15's Avatar
Default Re: CODE P0441 AGAIN
Service manual states:
'P0441 - Evap Purge Flow Monitor - Insufficient or excessive vapor flow detected during evaporative emission system operation.'
99% of the time, this is a result of a loose gas cap after filling. It will reset after you clear the codes. If it keeps coming back and it isn't the cap, it's probably an issue with a leak detection pump and would need to be replaced.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 01 Oct 2010, 02:32 pm
People can tell me I'm crazy all they want. I think somethings getting wet.
I have chronic P0441 disease. It's not the gas cap. I swear its my windshield washer nozzles dribbling on the PCM.
Another thing to note - TS Nicole came through here and rained for a good 36 hours - Prior to this I haven't used my washers for 2 weeks (no rain). WIthin 5 minutes of using them I got a P0441 at the light.
Old 01 Oct 2010, 03:57 pm
Freezinghot's Avatar
Dont use them then
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
P0441 CODE cllwyrc Tech & Performance Forum 2 16 Apr 2010 11:30 am
P0441? umm... what? CruseadorPT Tech & Performance Forum 5 03 Sep 2009 08:59 pm
P0441 - not the gas cap bobdole369 Tech & Performance Forum 1 16 Jun 2009 11:53 am
Code P0441 AkiraCruiser General PT Cruiser Discussions 4 09 Apr 2009 07:02 am
P0441 error code apollobey Tech & Performance Forum 2 07 Oct 2005 09:38 am
