PCV HOSE HELP
Old 18 Sep 2010, 01:57 pm
Exclamation PCV HOSE HELP
Hi, I'm new to this forum but I have used it many times in the past, it has been helpful, except!
Forgive me because I do not know much about mechanics so I will do my best to explain what I'm talking about
I'm experiencing a problem with my 2002 PT "touring edition", When the vehicle is ON I noticed a "hissing" noise. I took off the plastic cover to unveil a hose that is split and sucking in air. When I put my finger on the hose it brings the cars RPM's down as if it were to stall, but then idles back to normal. I've been told that it is called a PCV Breather hose. Though, no parts store seems to know what i'm talking about. The hose goes from the engine, back to somewhere around where the air intake would happen. It seems to have a sharp almost "U" turn shaped bend in it. So I don't think I could get any other hose to work with out it kinking.
I can't seem to find this hose, It seems simple enough to fix.
Any help would be greatly appreciated!
Old 18 Sep 2010, 02:31 pm
Default Re: PCV HOSE HELP
Go to the dealer and buy the hose.
Jerry
Old 18 Sep 2010, 02:45 pm
I agree with Jerry. I tried looking up the hose but couldn't find anything but the valve itself. In the meanwhile, wrap some black electrical tape/small piece of duct tape around the split till you get a new hose.
Old 18 Sep 2010, 02:54 pm
Dealer-only item. I just replaced mine a couple weeks ago...$20.70.
Old 29 Sep 2010, 03:45 am
chris15's Avatar
Yep, hose is a strange one-- it has different inside diameters on both ends, and also does that cute little 180* degree turn/twist deal. Gotta love Chrysler!
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 04 Oct 2010, 05:25 am
I too had the same problem. Although my Ltd Edition PT wasnt just hissing it was overheating too and sounded like it was going to stall. Took the engine cover off and noticed the split pcv hose. I think the oil in the hose has made the rubber rot. I replaced it temporarily with a hose of a similar size with couple of jubilee clips (just so I could drive it home) - but you have to make sure the hose doesnt kink which is difficult! and means you wont be able to get the engine cover on until you get the proper piece of hose. - as I say, dont try this unless you have to) Car now normal. I have ordered a new hose so will swap when I get it. Runs perfectly. What I want to know is, should I change the pcv valve too? Could this be responsible for 'rotting' the hose?
Old 04 Oct 2010, 04:11 pm
The valve is pretty cheap and you can pick them up at auto stores rather than a dealer. If you want to see if it's working, take it off and shake it. It should make a rattling noise from inside the valve. If it hesitates or doesn't rattle at all, replace it. Better yet, if you have 40/50,000 miles, just replace it, no questions asked.
Old 16 Jun 2013, 05:26 pm
gcb gcb is offline
for the registry, it's item 4884246AA in mopar's code
if you don't have a dealer nearby, you can buy even at amazon
Mopar Hose Polution Contro : Amazon.com : Automotive
Old 17 Jun 2013, 03:50 am
Gid; replace the pcv valve too. Mine cost $15~ from the dealer. I believe their product would have valving made more specific to their engines.
Old 17 Jun 2013, 08:30 am
Actually they are nothing special and under NitroPT's testing was not first in quality. Leaking is a big problem with all the brands out there. Boosted PT's most affected. That said, replace it, they all go bad.
Tags
hose, pcv, suction
Coolant hose, overheat juliemom Tech & Performance Forum 1 14 Jul 2010 05:43 am
Suction Hose Replacement: Burger Feedback and Support 0 05 Jul 2010 06:17 pm
Hole in a rubber hose?! Magu Tech & Performance Forum 5 03 Jun 2009 04:14 pm
Complete Silicone Hose Kit pttuning The Detail Shop 1 16 Apr 2009 03:18 pm
Hose head BoyJusCruisin Tech & Performance Forum 2 30 May 2002 12:32 pm
