engine block casting number location
Old 19 Sep 2010, 02:35 pm
Default engine block casting number location
Anyone got any pictures of the location of all 2.4L engine block casting number.
I wanna certify and document the location.
Old 19 Sep 2010, 05:20 pm
Default Re: engine block casting number location
dont know the location but sounds someone is trying to erase them
Old 19 Sep 2010, 05:30 pm
From a cylinder head replacement company:
Your PT Cruiser head has an identifying casting number that will be needed in order to ensure that you get the correct cylinder head. This number is cast into the head in the form of raised numbers. It is on the rear of the head on the opposite end from the pulleys. There is also a number on the back side of the magnetic sensor on the rear of the intake cam. You must remove the sensor with a torx bit and turn it over to see this number.
Water Pump - ( Block Casting ) DigitaL101 Tech & Performance Forum 1 22 Apr 2010 09:25 pm
Diesel (CRD) Engine Identification Number c13ckb Tech & Performance Forum 7 14 Feb 2010 08:35 pm
Diesel (CRD) Engine identification number. c13ckb Feedback and Support 2 13 Feb 2010 12:46 pm
Help needed! Can't Locate Engine Number PTNoob01695 General PT Cruiser Discussions 1 11 Sep 2009 09:11 am
Hole in Engine Block KathyD Tech & Performance Forum 2 15 Nov 2008 07:14 am
