Upper Motor Mount Issue
Old 20 Sep 2010, 10:02 pm
Exclamation Upper Motor Mount Issue
Hi I own a 2003 PT cruiser Touring Edition, and recently the upper motor mount bolt connected to the engine broke and so on the passenger side the engine dropped bad... not cool to see. So I got the same bolt put it on the same place.
So far so good but when I compare to the pt cruiser of my father in law, I see that my engine is still too low on the passenger side :S. Its like there's too much pressure on the upper motor mount and it might break the same bolt again.
Now my question is, besides the upper and lower mounts is there any other part that support the weight of the engine on the passenger side ? because if there is such thing, it might have broke too, and maybe its why the upper mount is over stressed..
thanks for your attention !
Old 20 Sep 2010, 10:42 pm
Default Re: Upper Motor Mount Issue
I think I found what it is. I circled it on my attachment. its called engine mount. I think this broke too that why I have too much pressure on the upper motor mount. tomorrow Ill be fixing it I will confirm it if it happens to anybody else
Old 20 Sep 2010, 11:01 pm
Send a message via AIM to mole
there is a bolt that goes there. i guess its missing?
Mole'@DCR
2004 SRT-4 built
2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned.
2003.5 MazdaSPEED Protege stock
2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s
Contact me for all your BWS/DCR needs..........
Old 21 Sep 2010, 03:19 pm
Yep I just found out the broken bolt that goes right inside the right engine mount, its a torx bolt
it goes in the middle of the engine mount ->
engine mount
and you can see it by removing the splash shield and the little plastic plug
this is where you can see the torx bolt
Old 22 Sep 2010, 12:59 am
Now struggling with this piece of torx bolt stuck in the block... I drilled it all that I could, not enough to extract it... do you guys know any other way to remove a stuck broken bolt ??
Old 22 Sep 2010, 01:24 am
engine mount
ya its like a t56 i think
cant remember, its been awhile since i swapped my motor
Mole'@DCR
2004 SRT-4 built
is it tight in there ?
Mole'@DCR
2004 SRT-4 built
Tags
motor mount
motor mount cllwyrc Tech & Performance Forum 13 04 Feb 2012 09:02 pm
Help finding Motor Mount Bracket/Flange? Upper billzilla General PT Cruiser Discussions 1 05 Nov 2011 08:51 pm
Motor Mount CityGirl70 Tech & Performance Forum 11 20 May 2011 10:51 pm
Motor Mount "fixes"? Stephen R. Tech & Performance Forum 5 29 Sep 2003 07:29 pm
Motor mount mod. PVO PT Turbo Wheels/Suspension/Handling 4 28 Jun 2003 02:30 am
