Battery Change Causes Airbag Problem?
Old 21 Sep 2010, 11:44 am
Unhappy Battery Change Causes Airbag Problem?
We have a 2004 Turbo Cruiser and recently the battery went dead. After replacing it the airbag light came on so we called the dealer. They made appointment to reset it for a few days later.
In the meantime we went to get it smogged but it wouldn't pass as the airbag light was on - the guy said drive it for about 100 miles and it would reset. (It hasn't)
At the dealer's appointment they said that it needs a new airbag module and was going to cost $430! We asked for the code and all they told us was output driver 1.
The airbag was fine until we got the new battery - something sounds very weird here. Any help?
Old 21 Sep 2010, 04:51 pm
Default Re: Battery Change Causes Airbag Problem?
Can't find anything in a fast search. Is the airbag light still on or did the dealer clear the code? Did you try retrieving the code yourself?
How to retrieve fault codes.
Old 22 Sep 2010, 11:14 am
Thanks for posting the retrieving link
HID Kits - Xenon Lights
Old 23 Sep 2010, 04:04 pm
mdfrodolives's Avatar
I had the airbag light coming on for longer than normal, and a mechanic told me it was the airbag clock spring. But the following day, all my instruments started acting up. It turned out that I simply needed a new battery. Once I put the new battery in--all the problems with lights disappeared.
Try unhooking your battery cables and re-attaching them. sometimes a battery problem can make the PT do silly things....
Tim
Tags
airbag light, airbag module, new battery
Problem with Passenger Seat Airbag Sensor Orangestng General PT Cruiser Discussions 1 06 Aug 2009 04:35 pm
How do you change a battery in a 2002 Pt Cruiser Turbo? ptshmoozer Tech & Performance Forum 5 31 Jan 2009 03:24 pm
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
How difficult is it to change battery cables? sawdust123 General Turbo Discussions 0 20 Aug 2007 12:57 am
Airbag problem - light and chime keep coming on cruiserbabe4 Tech & Performance Forum 9 22 Jul 2004 01:00 pm
