2003 Timing belt
Old 21 Sep 2010, 10:31 pm
Default 2003 Timing belt
Hey all! First time here with a question. I replaced my timing belt after it striped, I went through all the steps, timing marks etc... and researched all I could find on this site being careful not to miss anything (Thank God this site exists!).When I fired it up it idles great, however when I ran rpm's up it surges starting around 3500 and jumps to around 4000 and no higher. Back to the drawing board, check and recheck, same result. Timing marks are dead on as far as I can tell before and after start up. Any ideas?
Old 22 Sep 2010, 12:35 am
Default Re: 2003 Timing belt
The computer is shutting off the injectors/fuel pump (I forget which) around 3500 to stop you from over revving/hurting the engine when your at idle. It's a normal process. There's nothing wrong. You might not have noticed it before, but it's always been that way. Take it for a ride, it should go all the way up to red-line without a problem if everything else in the engine is OK.
Old 22 Sep 2010, 06:24 am
Thanks for the quick response! Your right I had not noticed before, I'll give it a shot after work today and let ya know.
Old 23 Sep 2010, 06:21 am
Cool Re: 2003 Timing belt
Thanks again for your input, I got home from work last night and buttoned everything up,took a test drive and I'm CRUZIN again!
Old 23 Sep 2010, 06:27 am
Timing belt Pt 2003 GT Turbo RSavage Tech & Performance Forum 14 11 Sep 2010 03:27 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
timing belt greg55 Tech & Performance Forum 1 08 Mar 2010 09:06 pm
2003 GT timing belt CherylK Tech & Performance Forum 8 19 Oct 2009 07:51 am
timing belt clevelandmike Tech & Performance Forum 2 08 May 2006 12:28 am
