2006 wont start, battery is good
Old 22 Sep 2010, 06:57 pm
Samson's Avatar
Question 2006 wont start, battery is good
Ok, I have posted previously about the stretched ignition wires (which I am still having problems with) and how they light up the instrument panel and shut the car off for a split second. The car was still running ok other than that until today.
I replaced my battery 2 weeks ago. Today I started the car, no problem.
Parked the car for an hour, and when I tried to start it again it just made a single click sound as I turned the ignition to start. I initially thought another bad battery, but it tested fine. Would this be a bad starter?
It is not even making the multiple click sound like when the solenoid is trying to engage. Each time I turn the key to start, it just makes a single click sound from the starter area. Could the problem I have been having with the bad ignition wires (I think) shutting the power off and on again fried the starter?
My Little PT is DOA right now. Any help at all would be greatly appreciated.
Shawn
Old 22 Sep 2010, 07:10 pm
Samson's Avatar
Default Re: 2006 wont start, battery is good
Is it possible that is the starter relay? I didnt even realize it had one until I started looking online. Where would the starter relay be in the engine compartment?
Old 22 Sep 2010, 07:20 pm
Samson's Avatar
Another thought, could it be a negative ground fault? Where is the ground attached to the engine block on this year?
Old 22 Sep 2010, 07:40 pm
You have the starter, starter solenoid and the starter relay. The relay is in the PDC (Power Distribution Center) that's in the engine compartment under the air filter.
Old 22 Sep 2010, 07:55 pm
Samson's Avatar
Thank you Crewzin. Using your best guess, would you think my starter is bad?
Hearing just the single click when I try to start the engine (and knowing the battery is good) is what lead me to believe its the starter.
Old 22 Sep 2010, 08:05 pm
Single click, could be a stuck solenoid or bad connection between battery and solenoid. I'd still try and jump start it to see if more power kicks it over. You can also tap the starter/solenoid or run 12v right to the starter.
Old 22 Sep 2010, 08:10 pm
Samson's Avatar
Thank you very much Crewzin!
I tried tapping the solenoid (although maybe not hard enough, was hard to get to). How would I run 12v right to the starter? Can the solenoid be replaced separately?
Old 22 Sep 2010, 08:24 pm
I was told that the solenoid isn't sold separately but someone on this forum did have it rebuilt.
How to Test a 12 Volt Electric Solenoid | eHow.com
Starter Troubleshooting
Old 22 Sep 2010, 08:32 pm
Samson's Avatar
Thank you again Crewzin!
Those two links is exactly what I was looking for, your a life saver.
Old 22 Sep 2010, 08:37 pm
Thank Google. My fingers do the typing, Google comes up with the answers.
Pt wont start chrisohan Tech & Performance Forum 19 10 Aug 2010 09:48 pm
02 pt wont start J_GEISLER Tech & Performance Forum 3 19 Jun 2010 10:39 pm
2006 Touring Ed. wont start.... help!!!! marvinev General PT Cruiser Discussions 4 18 Feb 2010 06:42 pm
2001 Wont start. Freshly charged battery thakfu General PT Cruiser Discussions 4 19 Jan 2009 02:14 pm
07 TE PT wont start PLEASE HELP!!!!! Norma Tech & Performance Forum 10 08 Dec 2008 08:58 pm
