Fuel problem-2001 PT
Old 23 Sep 2010, 11:00 pm
Default Fuel problem-2001 PT
First, hello to all, need help. I have a 2001, PT, 2.4 which has 138,000 miles.
It will run for 20 or so minutes and shut off, code out 1282, which states fuel pump or delivery problem. As well, 1132, which is cam sensor. I replaced the cam sensor, and still coded out. What is misleading, is why will it run for 15-20 minutes if the pump is bad. I checked the relays, and switched them around, no effect. I'm confused? Likewise, no fuel filter I can find, or is there one?
Old 24 Sep 2010, 12:36 am
Freezinghot's Avatar
Default Re: Fuel problem-2001 PT
Does it completely shut off? or go into sort of a limp mode with a rev limiter?
Anyways 1282 is : P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 24 Sep 2010, 01:57 am
Sorry about that, I confirmed the codes, and I got a 340, no cam signal to ecm, 1282, Fuel pump relay circuit, 1495, Leak Detection Pump Solenoid circuit, 645, A/C clutch relay problem and last 1193, Inlet temp sensor voltage wrong.
2001 radiator fan problem koor Tech & Performance Forum 14 23 Aug 2010 06:47 pm
2001 PT cruiser, no spark, no fuel..?..?..? ozmr Tech & Performance Forum 9 19 Jun 2010 10:36 pm
2001 pt has weird won't start problem monitor51 Tech & Performance Forum 13 17 May 2010 09:05 am
My 2001 problem...Help a brother out... WalterZoomie Tech & Performance Forum 3 10 Nov 2009 08:03 am
2001 radio problem beau526 Sound and Security Forum 3 25 May 2007 12:58 pm
