2006 a/c fan issue
Old 25 Sep 2010, 11:01 am
Angry 2006 a/c fan issue
The a/c on my 06 Cruiser blows warm when car is stopped and idling and when in park. I can hear the compressor cycling on and off but the fan does not seem to be on. I've read other posts about the fan, but I was wondering what would be a good way to test the fan. There is a connector on the shroud after the relays with one black and two blue wires. Could you jump these to see if both fans speeds work? Could it just be the pcm not sending the correct signal? Is it the low pressuer switch? I really don't want to go back to the dealer since I trust them as far as I can throw them.
Old 25 Sep 2010, 11:47 am
Default Re: 2006 a/c fan issue
Welcome mv to the Forum!!! If you do a search for fan you will find more info than you want.
Old 25 Sep 2010, 04:08 pm
Sounds like you have two problems. Fast cycling of the compressor should mean your low on R134a but the fan should be on when the A/C is running. I'm not familiar with the 06 and above wiring layout so can't help you test the fan.
03 GT AC issue freakengine Tech & Performance Forum 5 04 Sep 2010 10:06 pm
02 PT issue jparksp Tech & Performance Forum 4 18 Feb 2009 12:11 am
A/C issue. hermtm2 General PT Cruiser Discussions 9 26 Jul 2008 08:40 pm
2006 CHRYSLER PT CRUISER AUTOMATIC FACTORY WARRANTY, VERY CLEAN CAR (2006 CHRYSLER PT skylight craigslist 0 15 Jul 2007 01:10 am
