'04 limited turbo throws code p0522 and p0508
Old 01 Oct 2010, 10:35 pm
Default '04 limited turbo throws code p0522 and p0508
Hello i'm new to the group. But it has been very helpful to. I have an 04 touring edition turbo and i've only had it 6 weeks. It's use with 57k miles on it now. I've replaced the o2 sensors and car still stalls. shows new codes p0522 and p0508, which are the oil pressure and idle air. has anyone else had this problem and what should i do to fix?
Old 02 Oct 2010, 01:11 am
Freezinghot's Avatar
Default Re: '04 limited turbo throws code p0522 and p0508
It could be a number of things.Oil is burning, oil is leaking, your oil pump, or your oil sensor.
If its burning i guarantee you would know, so thats probably not it.
If its leaking you would be able to see it on the ground.
Ive personally never seen an oil pump go though, so i doubt thats it.
I say replace your oil sensor and see if that fixes it. Probably will
Is it still covered by warrantee ?
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 02 Oct 2010, 06:43 am
P0508-IAC VALVE SENSE CIRCUIT LOW
The IAC valve is located behind the throttle body. Check to make sure it's fastened on securely and all the wires are tight. If it looks good, take it off and clean it or just replace the valve itself. If it's not working properly it will cause stalling problems.
Old 10 Oct 2010, 12:02 am
thanks for all the help. i've found this site very helpful. first my warrenty is up. second i've cleaned the valve engine light went off. plan on replacine the valve and the oil sensor because it only stall after a long trip like a thirty or forty min drive, the engine light comes on and then flashes for a while. thanks again for the help.
Old 10 Oct 2010, 06:43 am
VNT's Avatar
VNT VNT is offline
Get a TB gasket and take the TB off. Then remove the IAC and TPS. Before you yank the TPS, crack the throttle blade and note the position. The TPS has to seat in the TB to line up correctly with the Throttle blade so it can track the positon of the throttle. anyhow when you put the TPS back in it has to line up correctly and you will know by operating the throtle by hand with TB off the car.
So clean the TB and the passage ways in the TB where the IAC is. Also wipe down the pintel on the IAC so it seats correctly. Carb cleaner works good.
Your car is stalling and the oil pressure drops because the load bogs the engine down. Clean the TB and IAC and I bet your stall goes away as well as you oil pressure code. worst case get a new Mopar IAC and replace it, do not get aftermarket on sensors and electronics.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 06 Dec 2010, 04:24 am
well as of today i have changed the Iav and i'm still stalling and have an engine light. i cannot drive long distances and i've tried the engine cleaners. i want to do what the last post says but i'm lost in the language. i have no idea what the tb and tbs are.
Multiple Codes (P0340/P0522) higear4 General Turbo Discussions 19 05 Sep 2011 05:30 pm
New to Me 01 PT Limited Non Turbo h100250 Tech & Performance Forum 13 16 Oct 2009 11:20 pm
02 PT limited 40K mi. Error code PO171 Mac02 Tech & Performance Forum 5 17 Jun 2009 09:38 pm
042.4 turbo limited rob_04ptc General Turbo Discussions 4 02 Feb 2009 07:14 pm
Will the Short Throws work on the GT's TurboDave Turbo Performance 11 05 Jun 2003 10:47 am
