cant get the engine to catch
Old 03 Oct 2010, 11:03 am
jamesndella's Avatar
Default cant get the engine to catch
have an 04 PT. Recently bought the car from a friend, car has been sitting for 6-7 months. Replaced bad cam and crank sensors and replaced the battery. Starter turns the engine, but it wont catch. Code check shows no problem. I am leaning towards bad fuel or a clogged line but any other ideas would help.
Old 03 Oct 2010, 12:12 pm
Default Re: cant get the engine to catch
Why was it parked for 6-7 months? Was some work done prior to the car being parked (i.e. timing belt) that might lend a clue?
Did you check to ensure that you have spark?
If you have spark and nothing was done to the car, then you probably need fresh fuel.
Old 03 Oct 2010, 01:30 pm
Is there anyway to check for a spark without having to buy a dummy plug?
Old 03 Oct 2010, 11:02 pm
car was sitting for short time because instead of repairing the car, the previous owner bought a new one, so i got this on the very cheap
checked for spark at first plug, have spark
removed at least half of a full tank and repalce with a quater of premium, but still nothing
going to check the starter just to make sure its spinning fast enough
a few other questions:
1. when replacing the cam sensor does the engine have to be at TDC? I didnt put it in, but wondered if it wasnt, could this be my issue...
2. the crank sensor was already provided for me, but the one i was given was full plastic and didnt look like the the one I took out. Wondering if anyone else used the full plastic or should I try to find something more similar?
Old 04 Oct 2010, 10:00 am
Our PT's do not care for aftermarket sensors, buy OEM's.
Oil Catch Can jingks Turbo Performance 4 24 Mar 2008 12:18 pm
Catch Can - Why? duffner General Turbo Discussions 1 27 Dec 2007 12:30 am
What's a catch can? purple people eater General PT Cruiser Discussions 2 13 Jun 2005 09:48 am
Catch Can? nozzano22 General Turbo Discussions 6 04 Nov 2004 03:16 am
Oil Catch Can crazie.eddie General PT Cruiser Discussions 30 30 Oct 2004 06:23 am
