Oil Leak 
Old 03 Oct 2010, 02:56 pm
Unhappy Oil Leak 
Hi All,
I have a 2004 pt cruiser with 116,000 miles that is spilling out oil from the engine. I seem to lose about a quart every few days. I've happened to notice that the oil doesn't pool in one spot under the engine, but is sort of spotty under the entire area under the engine, as if it's spilling from everywhere. I've been checking the oil level daily but I'm sure I'll have to get this fixed soon. If anyone has any idea where/why this oil is leaking PLEASE let me know. I'm hoping this will be a relatively easy/inexpensive repair....
Old 03 Oct 2010, 03:15 pm
Default Re: Oil Leak 
Just take it somewhere (anywhere) that has a lift and they will check it for you. That's one of the things the lifts are for. Instead of us guessing, and that's what it would be since we can't see your engine, you would very quickly know exactly what your problem is.
Jerry
Old 03 Oct 2010, 03:27 pm
Unless it's all over the bottom of the engine in which case they will have to power wash it off so they can hopefully see where it's coming from. You might have to stop by a second time, maybe the next day so they can spot where it's leaking from.
Old 04 Oct 2010, 12:29 am
Usually oil leaks that severe come from main seals or cam seals.
But yes, you'll probably need to just take it in to get checked. They'll probably put some dye in the oil and have you come back in a day or two and use a UV light to pinpoint where the leak is coming from.
-Chris
Old 04 Oct 2010, 10:01 am
That's what I'll do then. Thanks.
Old 04 Oct 2010, 11:17 am
Dino's Avatar
Since you have 116000 miles and if it is a seal of some sort it's most likely not going to be cheap, if you haven't done the timing belt and water pump you should combine it and do it all at once. Good luck
Old 04 Oct 2010, 11:43 am
X 2 IMHO
Old 05 Oct 2010, 03:52 am
This will only work it if turns out to be a cam seal or front main seal. If it's the rear main, there's no easy way around it.
-Chris
Tags
engine oil, leaks, oil leak, oil light
07 PT with Oil Leak jstcuz Tech & Performance Forum 14 10 May 2012 01:03 pm
AC oil leak robinjoe General PT Cruiser Discussions 4 16 Sep 2005 03:38 pm
Oil Leak PT Woody Tech & Performance Forum 10 21 Jan 2005 12:43 am
ATF Leak shlalk General PT Cruiser Discussions 12 24 Mar 2004 09:05 am
First Oil Leak? Ack! beebs General PT Cruiser Discussions 4 18 Oct 2003 10:55 am
