Hello
Has anyone had coolant boiling over in the reservoir tank I have a 06 Pt Cruiser Non Turbo. It started boiling coolant after I turn the car off. I replaced radiator cap and T-stat, and the boiling decresed, but It still do it after a drive of 20 minutes. I flush the old coolant and replaced with new one, bleed through the valve below the t-stat but it still do it. Any ideas? Thanks |
Can the type of coolant be the problem?
The car had Prestone 50/50 (green one) for 6 months and everything worked OK. Now I put Chevron Dex-Cool (orange one) , is this OK? Thanks |
There is a Xerex antifreeze that is okay (Napa has it and will look up the right #).
Check that the engine fan comes on - start car and turn on A/C - fan should come on.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
If like me you have trouble finding it than you can order from these guys with free shipping
Approved Vendor ZXGO5RU1 Antifreeze/Coolant |
Is there anyway to clean the system??
How do I know if its clog? When I changed the t-stat, i ran water trought the upper side of the radiator, and it came out from the t-stat hole in the engine? Thanks |
If the Dex-cool or the Green stuff were in the system for any length of time, the radiator is clogged and that is probably causing your problem. (The green stuff -may- be less cloggy.) It does not take long for the wrong coolant to ruin a radiator. If you bought the car used, you should assume that it had the wrong stuff in it.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring |
Thread Tools | |
Display Modes | |
Boiling water sound under the hood drivers side | csd | Tech & Performance Forum | 19 | 20 Aug 2011 08:12 pm |
2004 PT Boiling Over Help | 2004 | Tech & Performance Forum | 10 | 18 Dec 2010 01:43 am |
Car is off, Boiling Coolant | ptcruzrmama | General PT Cruiser Discussions | 17 | 15 Aug 2010 12:21 pm |
Boiling over - not overheating | ionheavens | General PT Cruiser Discussions | 12 | 19 Jan 2010 12:01 pm |
replaced tranny now its boiling over | wreksta | Tech & Performance Forum | 4 | 16 Sep 2009 02:22 pm |
