Fellow cruisers here is a mod I did back in Feb 02 with our first cruiser and I just finished it on the 09 we recently acquired. As you know the inlet on the stock airbox is very small abd restricts airfllow. This mod will open up the inlet to just under 3 inches which will improve performance. This can be done with basic tools found in a well equipped shop or garage. I have a bandsaw but a hacksaw can be used. A dremel tool is helpfull as well as a drill and sanding disc. I did this because I just can't justify the expense of a so called cold air intake setup. This mod is less than $10 and only takes a couple of hours to do. You need a 3" pvc 90 degree elbow that has female and male ends. Here are the steps:
1. cut the female flange off the elbow and then cut the flange to .187 wide 2. remove stock inlet snorkle and open hole to accept the male end of the elbow 3. glue the small flange on the male end of the elbow on the inside of the box as shown 4. fabricate (2) mounting clips - 3/4 x 3/4 x 1/2 steel or aluminum - drill 3/16 holes as shown 5. at this point you need to remount the box and correctly position the new inlet and mark the position because the inlet is slightly off center 6. drill and attach the clips using 10/32 screws and fiber locknuts 7. reinstall the box and check for fit - I had cut about 1/4" off the end of the inlet to let the airbox mount all the way down on the studs 8. after you have finished the trimming sand the new inlet and prime and paint I used some high temp black I had which isn't a match but still looks fine 9. Run a small bead of black silicone around the base of the new tube where it attaches to the box and you are done. 10. Enjoy! Your mileage should improve a little. Last edited by CREWZIN; 07 Oct 2010 at 10:06 am. |
Thanks Merlin. Will put that up in the HOW TO section as a sticky.
"John's steel blue" won't need one. He's got my old one. I used differant style pipes than you did (still 3") so when i glued the two pieces together they formed a moveable joint as they contacted the shell of the air box on both sides to hold it in place. By doing it this way I could clock the pipe to fit easier in the fenderwell hole as I was putting the box back in place.
Shortly after this install I switched over to the K&N Apollo system. Jerry |
![]() Quote:
Sorry but the Tornado won't help. Snake oil, waste of money.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Thread Tools | |
Display Modes | |
BOV Modification Install | wantaptcruiser | Stage Turbo Kits | 4 | 08 May 2009 11:03 pm |
Mopar Performance BOV Modification | wantaptcruiser | Turbo Performance | 2 | 28 Apr 2009 01:04 pm |
modification removed and... | steve smith | General Turbo Discussions | 7 | 09 Jul 2005 02:21 pm |
QUESTIONS ABOUT A MODIFICATION | santa ana cruiser | General PT Cruiser Discussions | 2 | 06 Aug 2003 02:28 am |
What's the first Reasonable Modification... | PTGT Redman | Turbo Performance | 3 | 22 May 2003 02:05 am |
