2004 pt no start
Old 07 Oct 2010, 01:29 pm
Default 2004 pt no start
I have a 2004 touring edition PT and two days ago while leaving the store I heard a scraping sound from the front passengers side. After returning home I went to leave later and it would not start. All I get is a whine when the key goes from on to run. I checked the error codes and got P0685 and P0688 going from this is replaced the ASD relay and still have nothing what so ever when the key is turned. Checked the battery and it is good. replaced the starter and battery last month.. I'm lost as to what this could be and really don't need/ can't afford a trip to the dealer.. Any help or suggestions would be greatly appreciated.
Old 07 Oct 2010, 01:42 pm
Default Re: 2004 pt no start
Had a similiar problem with my old Town & Country van a while back and it turned out to be a bad negative battery cable clamp. The factory cables are sealed in lead but over time the inside completely corroded. I cut the old clamp off and installed a new brass clamp from the local auto supply and that fixed everything. I was ready to change the starter as well but I had it rebulit not long before this happened and I knew the battery was good. Just wasn't getting current or voltage to the starter. It's worth checking.
2004 won't start scurvynave General PT Cruiser Discussions 5 03 Jul 2012 05:34 pm
2004 Turbo- Have to give it gas at cold start gorckat General PT Cruiser Discussions 1 22 Aug 2010 02:47 pm
2004 PT CRUISER wont start margarcia1028 Tech & Performance Forum 1 22 Jun 2010 07:43 pm
2004 PT Cruiser Wont Start brian_jill General PT Cruiser Discussions 12 18 Feb 2010 01:20 pm
