crank shaft positioning sensor?? help!
Closed Thread
Old 08 Oct 2010, 06:33 pm
Exclamation crank shaft positioning sensor?? help!
Yesterday when I went to pick up my car at a friends house, it took me 5 times to turn the key for my pt to fully start.. later on last night after my finance was leaving the car wash, while he was driving, the car just cut off.. and now will not cut back on..
When I turn the key, lights come on, radio comes on, etc (so it's not the battery). The car cranks but will not turn over.. It seems everything cuts on but the car itself.. I am being told it could be plenty of things.. but a mechanic earlier said that it sound like the crank shaft positioning sensor? Is this it!?
2002 Pt Cruiser
Old 08 Oct 2010, 06:42 pm
Default Re: crank shaft positioning sensor?? help!
Please go to the Performance section, look at this, it will tell you how to retrieve fault codes. It will give you somewhere to start.
BTW: Welcome to the Forum!!!
How to retrieve fault codes.
Old 08 Oct 2010, 06:45 pm
what would I do with the code it gives me?
Old 08 Oct 2010, 07:41 pm
Come back here and we'll help you. If you don't do maintenance yourself, we'll give you the information to take to your dealer or mechanic. The mechanic you talked to earlier was only guess at the cause. There's another sensor (Camshaft) that could also be the cause of your problem. The code should/could tell you which one it is.
OK, you started another thread on finding the code instead of coming back here. I'm closing this thread. No sense of having two going at the same time.
Closed Thread
Cam Shaft sensor problem lokiloki Tech & Performance Forum 10 28 Aug 2013 10:27 pm
Code 1391 Sometimes I can't see the crank or cam sensor signal CandaceMoore Tech & Performance Forum 8 29 Jul 2010 08:06 pm
Crank Shaft Russellhold Tech & Performance Forum 5 23 Feb 2010 07:13 pm
timing belt, crank shaft, knock and pcm what next phish2000 Tech & Performance Forum 2 21 Sep 2009 09:08 pm
Cam Shaft Position Sensor Johns Steel Blue Tech & Performance Forum 9 15 Apr 2008 07:38 pm
