Codes p1684 and p0340
Old 08 Oct 2010, 06:56 pm
Exclamation Codes p1684 and p0340
car will crank but wont turn over.. everything cuts on but car itself.. got these codes.. what do they mean?
Old 08 Oct 2010, 07:46 pm
Default Re: Codes p1684 and p0340
OK, just answered you other thread on the same subject. I see you followed Hooligan's advice and found the code. As I said in the other thread you could have a different sensor going bad other than the one the mechanic told you about and sure enough, the code is saying the Camshaft sensor is bad. Some owners (me included) have had the wiring harness to that sensor go bad rather then the sensor itself, so whoever does your mechanical work, tell him the wiring harness from the sensor all the way round the back of the engine has to be checked out and not to just change the sensor because of the code.
One more thing. The P1684 code saying the battery has been disconnect at one point. Nothing to worry about.
Help me please! P1684, P0117 & P0320 bananabond Tech & Performance Forum 12 09 Apr 2013 07:15 pm
P1684 Error Code-How do I fix it? StreetCruiserUK Tech & Performance Forum 22 24 Sep 2011 07:50 am
Multiple Codes (P0340/P0522) higear4 General Turbo Discussions 19 05 Sep 2011 05:30 pm
code P1684 gyrene General PT Cruiser Discussions 10 27 Aug 2010 08:35 am
Error Code P1684 j_desan Tech & Performance Forum 1 17 Mar 2010 06:37 pm
