Random check engine light
Old 08 Oct 2010, 09:30 pm
Default Random check engine light
Hi everybody!
This morning when I started my pt my check engine light came on. I turned off the car immediatlily and cycled the key on and off to check for any error codes, and there were none. I started it again, and the light came back on, but it drove perfectly normal like it always does. When I got home after school, (with the light still on), I disconnected the positive on the battery and left it for 15 minutes. When I reconnected it and started it, it ran fine and no more light. I think this is strange that it happened, but maybe because of the abnormal cold weather were having, something maybe got freaked out. Here in Westchester, CA, it normally gets down to about 59 degrees or so at night, but this morning it was a chilly 49 degrees. This may or may not been a factor, but it's my guess. Please feel free to express any ideas that you guys have on this for me.
Thanks alot!
-Hayden
Old 18 Oct 2010, 08:05 pm
SCBluePT's Avatar
Default Re: Random check engine light
Scammer alert! OK,he's been banned.
Old 19 Oct 2010, 06:58 am
Purely guessing, but when was last time plugs&wires were done?
Sometimes computer detects a missfire, but doesn't log an error code.
Old 19 Oct 2010, 03:06 pm
When you ran the fault check and had none, did it say "done" ?
Tags
check engine, cold, engine light, problem, starting
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 13 30 Apr 2012 04:49 pm
check engine light azphotog Tech & Performance Forum 3 13 Feb 2010 11:45 pm
Check Engine Light On vicky52 Tech & Performance Forum 11 23 May 2009 01:23 am
check engine light ccprez Testing 12 16 Mar 2008 08:22 am
