Engine light flashing
Old 09 Oct 2010, 12:43 am
Exclamation Engine light flashing
Hi all,
Earlier today, my check engine light came on, and i unplugged the battery and reconnected it and it got rid of the light. I noticed that when I turn the key to on but don't start the car, and all the lights come on and it chimes 5 times. After the chimes, my engine light flashes 10 times and the goes back solid. What does this mean??? I'm kinda freaked out! Please let me know ASAP!!!
Thank you!
-Hayden
Old 09 Oct 2010, 03:59 am
Default Re: Engine light flashing
Hayden,
When the engine light is flashing you should NOT drive the car. The computer is telling you that there's something wrong that need immediate attention. Do you know how to get the fault code from the computer? Follow these instructions, then come back here with the numbers that show on the dial and someone here will explain what needs to be done.
How to retrieve fault codes.
Old 09 Oct 2010, 09:00 am
Smile Re: Engine light flashing
Hey CREWZIN,
Thank you for the quick reply! The first thing I did when I saw that was the key trick for the fault codes. There were none, so I did some research last night online. I came across a jeep wrangler forum and some guy with a 07 wrangler had the same question I did, and it turns out to be if you disconnect your battery for 20 minutes, that resets the OBD II system, so when you turn the key to on, and all of the light do their tests, the engine light flashes because its saying that it is not ready for a emissions test, and if you take it in, there's a possibility it will fail. After a week of normal driving, the OBD system should recognize that everything is fine, and the light should stop flashing.
Thank you again,
-Hayden
Old 09 Oct 2010, 09:08 am
Hope it's a easy as that. This is from PT Do-It-Yourself.net
A flashing MIL implies that a serious condition may exist. I would suggest that you have the vehicle checked by your dealer ASAP. They will utilize a DRB scan tool to diagnose the concern. I would not attempt to drive the vehicle for any other reason. If you don't have a dealer fairly close by call them first to determine if the PT should be towed or driven in.
Maybe yours, because it only flashes when you turn the engine on, is a different scenario and the problem is not as serious as the flashing MIL (Malfuction Indicator Light) in other cases.
Tags
asap, engine light, flashing, warning light
Check Engine light flashing, PT stalling cherrytat Tech & Performance Forum 9 21 Nov 2016 05:45 pm
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
02 PT check engine light is flashing? PTkimmy Tech & Performance Forum 6 31 Aug 2010 02:36 pm
Check Engine Light Flashing on acceleration watkipk General Turbo Discussions 10 05 Dec 2009 10:24 am
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
