help! transmission noise
Old 12 Oct 2010, 06:13 pm
Default help! transmission noise
hello, I have a 01 pt. I've change the clutch like 1000 miles ago. and two weeks ago I've start hearing a ratling noise when I push the pedal clutch and it stops when I release the pedal. shifting and pedal feels good, no problem with that. some one had this problem before?. what could be the problem?
Old 12 Nov 2010, 06:32 pm
Default Re: help! transmission noise
I was experiencing something very similar to what you've described here. It was a strange grinding noise that would only happen when id press the clutch down then release it. It sounded like it was coming from the mid engine closer to the passenger side.
It turns out a bolt had come loose and was grinding into the tank which holds freon.
Have you checked there?
Old 12 Nov 2010, 09:27 pm
mdfrodolives's Avatar
I really don't know about PT Manual Transmissions, but with older cars, that noise used to indicate the "throw-out bearing" was just about throwed out.
Did you replace the throwout bearing when you replaced the clutch? I assume they still have a throwout bearing, of course ....
Tim
Transmission Pan Help Bentron General PT Cruiser Discussions 18 05 Jan 2011 07:31 pm
Auto Transmission noise at startup onemat General PT Cruiser Discussions 3 05 Oct 2010 09:50 am
transmission metz General PT Cruiser Discussions 5 15 Feb 2005 01:40 am
New Transmission Red GT General PT Cruiser Discussions 3 02 Nov 2004 08:55 am
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
