Problem with Idling?
Old 12 Oct 2010, 09:33 pm
03TibbyGuy's Avatar
Default Problem with Idling?
I have a 2003 Touring Edition Cruiser with about 98,000 miles on it.
Note: This ONLY happens when the A/C is on, when the A/C is off, the car runs and Idles fine.
When I'm stopped at a stop light or just idling in a parking lot and the A/C is on, the RPM's start to drop below about 700 and the car starts to stutter and act like its about to die and it actually did die just one time. But when I turn off the A/C, it does fine. The CEL is not on but every once in a while when the car starts to stutter, the oil light comes on, even after I had a fresh oil change. I'm hoping to get this figured out before spending the money at a shop so any help would be greatly appreciated.
Thanks
Old 12 Oct 2010, 09:54 pm
SCBluePT's Avatar
Default Re: Problem with Idling?
Read this post.It should help you out.
Really? A/C Compressor Stumble Is Normal?
Old 12 Oct 2010, 10:05 pm
03TibbyGuy's Avatar
thanks, looks like what i'm most focused on looking into would be either the A/C compressor and the Spark Plugs/Wires.
Hope it works
Thanks again
Old 12 Oct 2010, 10:07 pm
SCBluePT's Avatar
I would start with the plugs and wires.They are cheap and probably need changing anyway.
Old 12 Oct 2010, 10:16 pm
03TibbyGuy's Avatar
yeah thats what I was thinking. I'll pick some up next time I run to town since I'm like 40 miles away from the closest town and hope it works. I didn't even think about the spark plugs being the problem since the A/C played a role in the problem
Old 19 Oct 2010, 11:33 am
03TibbyGuy's Avatar
so just wanna update this. I went and bought new plugs and wires, installed them using the DIY thats on here. And no more problems. And it also fixed an acceleration issue I was having also. Runs way better. Thanks for all the help guys!
Old 19 Oct 2010, 11:51 am
Yup - the stock wires are crap. Glad it worked for you...
Idling Hesitation Ken Swenson Tech & Performance Forum 17 25 Feb 2013 04:50 pm
Idling issues FatalFurr Tech & Performance Forum 4 06 Apr 2010 09:17 am
A/C noise when idling 2002ptcruiserwoody723 Tech & Performance Forum 3 05 Nov 2009 02:16 pm
Idling Question about Stage 1 ??? retroman715 Stage Turbo Kits 8 26 Aug 2004 12:04 pm
Idling High? Too much noise.... saalfl General PT Cruiser Discussions 9 17 Jul 2004 10:40 pm
