rough idle after changing timing belt on 01 pt
Old 13 Oct 2010, 03:25 pm
Post rough idle after changing timing belt on 01 pt
i changed the timing belt on my pt cruiser and now it has a rough idle. i also replaced the spark plugs also but not the wires. on top of that now it has tripped a dtc p0134-o2 circuit no activity detected b1 s1. i have been told that it could possibly be the idle air control motor causing the rough idle, which i am also uncertain how to test. when i changed the belt i made absolutely sure to get the timing marks lined up exactly. if any one knows what may be causing these issues i would be happy to hear from you. thank you, randy
Old 13 Oct 2010, 03:41 pm
Default Re: rough idle after changing timing belt on 01 pt
Well look for easy stuff first, vacume lines, etc.. Something you took off is not on correctly (intake?).
Worst case the belt is on a cog off, I have only read on the belt change so NO IDEA if it will run a cog off, or what you may have on to lose or? I'm sure somebody will chime in.. Rough Idle is normaly a vacume leak or something not bolted on well in the intake.
Old 13 Oct 2010, 03:51 pm
Sorry, 9 out of 10 who had rough idle after a timing belt change were a tooth off. Like clok1966 said, check the easy things first but my money's on the tooth.
rough idle after changing timing belt CJDoble Tech & Performance Forum 7 30 Jul 2015 08:59 am
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
after timing belt idles rough dpmeeks Tech & Performance Forum 7 21 May 2009 06:00 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Running Rough...New timing belt, water pum and spark plugs lanies_ptcruiser02 Tech & Performance Forum 15 05 Sep 2008 09:59 pm
