ENGINE CODES HELP
Old 15 Oct 2010, 12:01 pm
Default ENGINE CODES HELP
Hello i am new to this forum but have read alot of good stuff on here so here goes my story my check engine light came on and had it checked and they gave me codes P0113,P0128 and P0481 does any one know what these codes are thanks............
Old 15 Oct 2010, 12:43 pm
Default Re: ENGINE CODES HELP
Just because I like your username.
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0128 Coolant Thermostat
P0481 High Speed Cooling Fan Circuit Fault
Old 15 Oct 2010, 02:50 pm
Diddo crewzin lol...ok so i know where the code P0128 coolant thermo is where can i find the other two codes and how do i know if they are faulty?
Old 16 Oct 2010, 07:49 am
The IAT sensor is the small black sensor that's pushed into the inlet tube of the air filter system. Here's a picture...
It would have to be tested with a scanner to see if it's bad.
The other (High Speed Cooling Fan Circuit), I would think if that wasn't working, you would have some signs like overheating when your sitting at idle. Try turning on your A/C and with the engine running, sit at idle for about 10 minutes. Watch your temperature guage. If it starts going over half way towards HOT, you might (probably do) have a fan motor problem.
Old 16 Oct 2010, 09:47 am
Just thought I would chime in on your IAT high voltage code...
I had that same code when I had a vacuum leak...check to make sure that you don't have one. My PCV valve hose cracked out from my vacuum gauge, and that threw the code.
Paul
engine codes petiecruiser Tech & Performance Forum 1 25 Oct 2009 03:48 pm
engine codes petiecruiser General PT Cruiser Discussions 3 25 Oct 2009 02:37 pm
Engine Codes help wareagleguy Tech & Performance Forum 3 02 Mar 2009 10:02 pm
OBD engine codes shodobe Tech & Performance Forum 7 27 May 2005 12:32 am
Engine codes Kroozah Tech & Performance Forum 8 31 Jan 2005 01:22 am
